Rhino fails to install Python runtime
Hi folks,
Currently experiencing an issue with Rhino where it is failing to install the Python runtime. This occurs when opening the ScriptEditor or when running Grasshopper and attempting to add a Python component to the canvas.
The ScriptEditor window displays a message of ‘Error occured during language initialization’.
The log shows:
"C:\Users\username\AppData\Local\Temp\colorama-0.4.4-py2.py3-none-any.whl"
Error 26/09/2024 10:51:52 [RhinoCode] Process exited with code 1
Error 26/09/2024 10:51:52 [RhinoCode] Error Initializing Python | Error deploying package "pylint-2.10.2-py3-none-any.whl" | ERROR: Can not combine '--user' and '--target'
   at Rhino.Runtime.Code.Languages.PythonNet.CPythonRuntime.DeployPackages(CPythonStartupSteps startup)
   at Rhino.Runtime.Code.Languages.PythonNet.CPythonRuntime.<>c__DisplayClass98_0.<InitRuntime>b__0(Access access)
   at Rhino.Runtime.Code.Languages.Runtime.Access.Run(String id, Action`1 task)
   at Rhino.Runtime.Code.Languages.PythonNet.CPythonRuntime.InitRuntime(CPythonStartupSteps startup)
   at Rhino.Runtime.Code.Languages.PythonNet.CPython`1.Start()
This problem only seems to occur on machines that also have Anaconda installed and uninstalling Anaconda seems to resolve the problem. As a lowly Desktop Engineer unfortunately I am not so well versed in all things Python related and was hoping to be pointed in the right direction.
We’re currently running Rhino 8.5 and Anaconda 2024.06-1 on Windows 11 Education 10.0.22621.4169 x64 (2009)
If I can provide any further information please let me know.
Thanks,
Luke
The new script editor is under heavy development and a lot has happened since 8.5. Try updating and see if that fixes the issue. Also, welcome aboard :slight_smile:
Thanks for replying I have gone ahead and updated a test machine to 8.11 unfortunately still receiving ‘Error Occured During Language Initialization’. when loading the ScriptEditor.
There seems to be an issue with the log file at C:\Users\Username.rhinocode\logs as it is incomplete.
Probably one for @eirannejad then, he would know.
@Luke14 Anaconda manages its own environments and configures system to force pip (Python’s default package manager) to install to a user local directory.
  • It usually sets the PIP_USER environment variable on your system (See --user flag
  • Alternatively it might add this option to the pip configuration file on the system (See Pip configs)
    [global]
    user = true
This is not a Rhino python deployment issue however I am gonna make some modifications to make sure our pip installer does not listen to these global configurations. I made a ticket here and will get this fixed ASAP:
RH-83985 Rhino pip listens to PIP_USER global env var
Many thanks for this update and the information :+1:
RH-83985 is fixed in Rhino 8 Service Release 15
Hi folks,
Sorry to be the bearer of bad news but the problem still appears to exist in SR13. If the pip.ini at C:\ProgramData\pip\ is set as:
[global]
user = true
Then the python component will fail to install. The above setting appears to be the default after an Anaconda installation.
I can get around this by closing Rhino and setting the pip.ini to:
[global]
user = false
and then deleting the .rhinocode directory at C:\Users\username and relaunching Rhino. The python component will then launch successfully upon loading the ScriptEditor.
Thanks. I reopened the issue.
Okay. I was able to replicate the issue with pip.ini file and put more fixes into Rhino 8 for this.
Thanks for your work on this Ehsan!
