I have my autosave set to the usual C:\Users\rbaltera\AppData\Local\McNeel\Rhinoceros\7.0\AutoSave\RhinoAutosave.3dm
Unfortunately they keep on going to the recycle bin.
What’s the trick to make sure they go to correct folder?
When Rhino deletes them to make a new autosave file, the deleted one goes to the Recycle Bin.
That is a HUGE safety net in the event the current autosave file is not there or damaged. Then you have a previous file you can Restore, Rename, and Open to recover your work.
