Rhino 6 appears to be moving old Autosave files to the recycle bin once they get overwritten. Is this likely to be a setting I have selected?
Thanks.
Thanks.
Cool, thanks Pascal.
I think I like it, an extra backup in case. Just need to remember to empty the recycle bin more often
That is what I do - there is also a setting to not save multiples in the recyle bin, just the most recent one, but so far here that fails, unless I am misunderstanding what it is meant to do.
https://mcneel.myjetbrains.com/youtrack/issue/RH-44858
Yes, i saw this setting too. I’ve set it as false so will see what happens.
Nope, the multiple saves to recycle bin still happens with it set to False.
