Round structural cover slab
Hello
I know there’s a lot of discussion on the forum about the Lunchbox with truss construction tool, however I don’t understand how to build a truss frame inside the circular surface (covering).
Now trusses are sticking out of contour, it shouldn’t be like this
I need the trusses to be built inside the edge of the circle, if possible (and using the Space Truss Structure 2)
Also note that the circle configuration can become a cut surface with panels to which the trusses will be attached, but don’t know how to do that either
STruss.gh (64.7 KB)
How can I assemble such a structure from frames (showing an example)?
01
STruss_re.gh (72.4 KB)
@HS_Kim thank you so much! You’re a lifesaver as always :wink:
