Hey!
So, I am trying to model this rough, brick like, texture.
This texture I made in ‘displacement’ for rendering but I want to print this on the object, as a rough surface.
All tips would be helpful to get the job done!
Kitty!
Hey!
Kitty!
Hi Kitty - ExtractRenderMesh
may get you something that will print OK.
WOW THANK YOU VERY MUCH!
I was searching for hours!
It worked into an stl file!
Love from Belgium
-Kitty
solved ? - check pascals answer as solution.
there is also the command
_Heightfield
