Rotation about Y-axis problem with 9 SR1
unable to rotate objects about the local Y-axis; no problem about local X-axis & local Z-axis…?
Art
Swift over the top exhaust.3dm (64.0 KB)
What command are you using to rotate the objects? Rotate? Rotate3D?
Which viewport are you using? Perspective?
David-
thanks for the quick reply on Thanksgiving!! mouse in perspective
Art
Which command or Gumball? If Gumball then someone else will need to assist - I don’t use Gumball.
David-
neither, have always used the mouse…
Art
Oh, rotating the view…
Are you trying to rotate objects relative to the coordinate system? If so the only way I know to rotate objects other than a command using the mouse is with the Gumball widget:
Or are you trying to rotate the view using the mouse? If so then check the settings for view rotation in Options > View
If you want Rhino 9 options to be the same as you use in Rhino 8 then you can use OptionsMigrate in Rhino 9 to import all Rhino 8 options.
David-
huge thanks; “view” suggestions worked like a charm!!
Art
