The rotate tool is stuck on one axis so when I try to rotate an object in the perspective view it will only allow me to spin it around, rather than in any direction.
I have scoured the internet and people seem to have had this issue before however what they did to solve it isn’t working for me.
I’m using the latest version of Rhino 7. Please let me know if you have come across this issue before and if you have a solution!
Rotate using what? The Rotate command? The gumball?
The default Rotate command rotates around the Z axis of the active CPlane, if you want to use some other axis you need to pick in a view other than Perspective or use Rotate3D or the Gumball.
Rotate is a 2D command and only rotates on an axis parallel to the Z-Axis of the CPlane in the active viewport. If you don’t want to change the CPlane, you can use the Rotate3D command and choose the axis with two points.
