RotateViewAround ObjectAtMouseCursor does not work
I always have View>Rotate set to ‘Rotate relative to view.’ When I change advanced setting RotateViewAroundObjectAtMouseCursor, nothing is changed.
By the way, Discourse rejected RotateViewAroundObjectAtMouseCursor in the title because this word is too long. I agree.
With that option set to its default, can you detect a difference when rotating the view in a perspective window with the Ctrl+Shift keys held while RMB-rotating over an object?
It makes no difference for me - the view tumbles the same way.
2024-06-10 - Ctrl-Shift Rotate View
In this screen grab, the first view rotation is the default one.
The mouse is over the tall box when starting to rotate. The tall box moves all over the view.
The second is with Ctrl+Shift. The mouse is over the tall box when starting to rotate. The tall box stays in the same position during view rotation.
Fwiw, I just want to mention/recommend a 3DConnexion SpaceMouse. If it is set to “Object Mode”, which seems the most sensible one, it will always rotate around the selected objects bounding box center. From Wim’s screen grab it seems like the rotation center using RotateViewAroundObjectAtMouseCursor is the front corner of the box, which is a bit odd.
I can’t imagine ever going back to navigating the viewport with the mouse and modifier keys. The Rhino native implementation of the SpaceMouse is the best I have come across.
It still makes no difference. Everything tumbles around center of the view. Did you set View>Rotate to ‘Rotate relative to view.’? The Ctrl+Shift is used to select subobjects. When I select subobject, everything tumbles around the subobject. Otherwise, the Ctrl+Shift makes no difference.
Standard Rhino does the same thing if you set it in Options>Modeling Aids>Gumball>Rotate view around Gumball.
I didn’t know about that option. Handy to activate so that in the rare case I do use the mouse, the behavior is the same.
Thanks for mentioning :slight_smile:
I wanted to mention that RotateViewAroundObjectAtMouseCursor will ignore objects that are layers that are locked, making it appear as though it is not working.
When I turn this option RotateViewAroundObjectAtMouseCursor to true it does not do anything for me. Does anyone have ideas as to why or a way to get that to work.
It is really annoying when you are zoomed way into an area of your model and can not click and rotate to see a specific area.
Thanks
