Hey is there an easy way to rotate the view by 90degree? thanks!
Yes, it’s well hidden:
Press SHIFT + ALT and you will be able to rotate the view…however move your cursor(now a hand) to the edge of the view. The cursor will change to a hand with a 5 and you will notice the vi rotation will be with 5 degree increments.
Or use the command _TiltView and use the Angle option in the commandline to set desired rotation.
HTH
-Willem
Thanks so much Willem! TiltView works, but McNeel should implement a reset view command and check the free hand behaviour. It causes trouble when you hover over the window below (4-windows view)
SHIFT+ALT doesn’t work for me, can you pls make a quick screencast? this tool is killer (saves as animation or gif and is free)
http://recordit.co/
I’ve got limited time atm but when you press and hold left Shift and left Alt and while pressed down; manipulate the view while holding down the RMB. Does that work?
-Willem
@willem Yes would work now. Thanks a lot!
Home and End keys step backward and forward through view changes.
@gregb You are right. thanks mate!
