HI;
I want the camera to rotate around the X-axis of the Cplane (0-360 degrees).
But when I run my code the X-axis will be reversed and after 180 degrees, the rotation direction will be reversed.
How do I solve them.
CRhinoViewport& viewport = RhinoApp().ActiveView()->ActiveViewport();
ON_Xform rot;
ON_3dVector axis = RhinoApp().ActiveView()->Viewport().ConstructionPlane().m_plane.xaxis;
ON_3dPoint or = RhinoApp().ActiveView()->Viewport().ConstructionPlane().m_plane.origin;
double angle = (-5.0 / 360.0) * 2 * ON_PI;
rot.Rotation(angle, axis, or);
ON_3dVector camx = viewport.VP().CameraX();
ON_3dPoint location = viewport.VP().CameraLocation();
ON_3dPoint target = viewport.VP().TargetPoint();
viewport.SetTargetAndCameraLocation(rot * target, rot * location, true);
dale
(Dale Fugier)
December 30, 2020, 6:44pm
#2
Hi @suc_kiet ,
Does this help?
CRhinoCommand::result CCommandTest::RunCommand(const CRhinoCommandContext& context)
CRhinoView* pView = RhinoApp().ActiveView();
if (nullptr == pView)
return CRhinoCommand::failure;
CRhinoViewport* pViewport = &(pView->ActiveViewport());
if (pViewport->View().m_bLockedProjection)
pViewport = &(pView->MainViewport());
if (!pViewport->VP().IsPerspectiveProjection())
return CRhinoCommand::nothing;
const ON_Viewport& vp_in = pViewport->VP();
ON_3dPoint camLoc;
ON_3dVector camX, camY, camZ;
if (!vp_in.GetCameraFrame(camLoc, camX, camY, camZ))
const CRhinoAppViewSettings& view_settings = RhinoApp().AppSettings().ViewSettings();
double angle = 2.0 * ON_PI / view_settings.m_rotate_circle_increment;
double target_distance = (camLoc - pViewport->Target()) * camZ;
// Rotate about cplane x-axis
ON_3dVector axis = pViewport->View().m_cplane.m_plane.xaxis;
ON_Xform rot;
rot.Rotation(angle, axis, ON_origin);
const ON_3dVector camUp = rot * camY;
const ON_3dVector camDir = -(rot * camZ);
ON_3dPoint target = camLoc + target_distance * camDir;
pViewport->SetTarget(target, true);
ON_Viewport vp_out = vp_in;
vp_out.SetCameraLocation(camLoc);
vp_out.SetCameraDirection(camDir);
vp_out.SetCameraUp(camUp);
pViewport->SetVP(vp_out, FALSE);
pView->Redraw();
return CRhinoCommand::success;
– Dale
Hi@dale;
Thank you, it is very helpful
