Hi Scott, I’ve been trying to do your example with Elefront and there seems to be a limitation on the add Component (Location) in that it doesn’t work on Planes that aren’t parallel to the XY Plane. I can’t orient my created Family Component at an angle.
Error:
Can’t rotate element into this position. {759412}
Is there a workaround for this? Also, can Revit deal with non uniform scaling of Families? Because I have a roofing model full of Instanced/Blocked Panels which are non uniformly scaled and I would like to keep them Instanced in Revit. Thank you.
