Hi there,
I have a set of blocks of which I would like to add it’s contents to Revit as new component families. For that I am using the ‘New Component Family’ gh component (following the tutorial Rhino.Inside®.Revit). This works fine, however the gh component only has a Location parameter, so I cannot get the other transformations to Revit. Is there a way to insert a component in Revit and set its full transformation matrix?
I don’t want to explode the blocks because there are many repetitions, so the model gets clogged.
@scottd, do you have any ideas maybe?
