Roof from VisualARQ 2 doesn't open well in VisualARQ 3
And, by the way, the is some bug with roof model. Here is a model made entirely with VA2 / Rhino 6, almost plain VA objects, plus some additional geometry (mostly planes) for controlling objects geometry. The file opened with Rhino 8 / VA 3, without model regenerating looks as it should be:
But regenerating it completely messes the roof geometry:
Looks like VA 3 doesn’t like roof slopes set to 90 degrees…
Cheers, Jaro
@jerry.bakowski Please share that file so we can check what’s going on.
Sent!
Got it! I’ll report it to the development team and get back to you when we fix it.
@jerry.bakowski I encourage you to open the same file with the new VA3 Beta version. You will get a nice surprise: New VisualARQ 3 Beta 5 released! - #6 by enric
Well, I’ve got encouraged and opened it :wink: The roof is fine now, but take a look at some walls, extended up to it:
Some part of them flows above the roof, up to their initial height. And - maybe it is some kind of a clue - there is only a core layer of the walls above the roof.
Cheers, Jaro
Hi @jerry.bakowski I didn’t notice that bug when I tested it. :thinking:
If you change the height of those walls to a smaller value (lower than the roof), the problem seems to resolve.
We will take a look at this anyway.
