Hi guys,
To enable a working 3d printing process, I need a helix that evolves along a loft.
The first idea was that I draw 3 curves to design an element. After that I offset the curves in both directions and connect the endpoints to get a closed path. I do that for all 3 curves, loft them and then divide them into layers. That works, but I have to print as a helix, rather than a single path, because there are problems with the endpoints while printing in simple layers.
The Loft should be the basic form of the helix. Does anyone have an idea for a component or an approach to the helix? This should rise 3 or 2.5 mm in one turn.
Thank you in advance!
Shouldbehelix.3dm (118.6 KB)
Helix.gh (13.2 KB)
