Hi guys
I am trying to use RIR to extract rooms for thermal simulation in IES-VE.
As a default, the rooms look like this when querying from Revit
However, I need the walls to finish at the wall center line for all interior partitions and to finish at the exterior face finish for all surfaces without adjacencies (in other words exterior walls, roofs, etc.).
I followed this tutorial which allows me to change the boundary location, but the only options at the moment are interior finish and center line.
So using the center line function would look correct, but in reality all exterior walls should be offset a distance corresponding to the half of the wall thickness.
Does anyone have a good approach to extract the rooms correctly?
