I can open Rhino from Revit but not GH…(I tried to uninstall and Install again RIR…but nothing changed…I currently use Rhino8 and Revit2025… I’m also a Tekla user…and Tekla 2025 works ok)
I got this error…
An error occured during GHA assembly loading:
Path: C:\ProgramData\Autodesk\Revit\Addins\2025\RhinoInside.Revit\R8\RhinoInside.Revit.GH.gha
Exception System.MissingMethodException:
Message: Method not found: ‘System.Drawing.Bitmap Grasshopper.Kernel.IGH_ObjectProxy.get_Icon()’.
I have used RIR in this morning. After finishing one project, opening up a nem Revit, this ERROR showed up.
I have deleted RIR, reinstalled, deleted everything with a special program that could connect to RIR. After this move Revit did not start… So deleted Revit and reinstalled it as well.
Now I have reinstalled the latest REVIT(25), RHINO8, RIR. Still not working.
GH starts anyway, but RIR components can not load in.
You are having plugins conflicts. Lets isolate from Revit addin and 3rd party plugins.
Revit 2025.3 and above ships with an Addin Manager that allows you can temporarily disable addins.
In Rhino you can disable via Properties/Plugins.
Grasshopper can be loaded via the Rhino command line with GrasshopperLoadOneByOne and say No to 3rd party plugins. Or uninstall via package manager/move the plugins out of the gh folder.
It looks like you have Wombat installed twice.
I updated Grasshopper on Rhino 8.32 to be more robust on these cases.
But it will not be available as RC until May 12th.
Based on this, it should be a plugin conlfict as you said.
Now how could I figure out, which plugin is the problem?(I have several, so testing out 1by1 should be a “z” plan.)
Started Revit..RIR to see if it works
4…repeat(2. & 3.) until it fails.
In my case IdeaStatica component caused the problem. So I deleted, now it looks like RIR works fine.
(I have not tried to download a fresh IdeaStatica component and see if it interrupt again or not.)
