Right click
we have a problem at grasshopper, right click doesn’t work on some component at input data, for example in offest curve component when i do right click on distance item, it doesn’t open menu.
in addition, i tried may times to uninstall & install Rhino, Unfortunately i still have this problem.
Hi -
Does that mean that right-clicking on the Plane input of the Offset Curve component always works and doing the same on the Distance input of that same component never works?
Hi -
If this is something that you see when you are NOT using the Ladybug plug-in components on the Grasshopper canvas, please keep this conversation in this forum. If it is something that you can only see when you also have Ladybug components, please reply in the Ladybug Tools forum.
In any case, we will need more information about this issue. If there is a specific Grasshopper definition in which this behavior manifests itself, please upload the gh file.
