Just running a quick tutorial on grasshopper and I have fallen at the first hurdle. I have created a point parameter in grasshopper, but when I right click to set on point and reference rhino nothing happens, but parameter turns green - no drop down appears. Any pointers?
Hi - that seems to work fine on my system running 5.5.3.
Could you please run the Rhino About command, click on the More info… and then the Copy to clipboard button and paste the content back into a reply here?
Third party kernel extensions
com.kairos.driver.DuetDisplay (1) 0A9F5387-316E-3D61-B9ED-D066346F8797
com.Cycling74.driver.Soundflower (2) 2D779840-7439-31E5-8A66-D786C3F47B75
Hardware information
Computer hardware
Hardware model: MacBookPro9,2
Processor: Intel Core i7-3520M CPU @ 2.90GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: Intel HD Graphics 4000 1536 MB
Memory: 1536 MB
Screen size: 1920 x 1080, 1280 x 800
Displays: PL2481H (94dpi 1x), Color LCD (114dpi 1x)
USB devices
Apple Inc.: iPhone
CHERRY: CHERRY KEYBOARD
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Computer, Inc.: IR Receiver
Apple Inc.: Bluetooth USB Host Controller
Western Digital: My Passport 0820
Bluetooth devices
Apple: Apple Wireless Mouse
OpenGL information
OpenGL software
OpenGL version: 2.1 INTEL-10.36.23
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
The only thing I can see here that is preventing us from reproducing this is that it is likely a High Sierra-only issue.
I’ll see if I can boot up High Sierra and reproduce this, but I doubt we will patch it because [reasons]. Given that we are not able to reproduce it on Mojave, I suspect it is a High Sierra-only bug…but that is pure speculation. If it were, I would expect we’d be hearing about it more, so it may be a combination of things.
I am unable to reproduce this in Rhino 5 for Mac 5.5.3 on High Sierra 10.13.6.
@peter15 I notice you have a couple of third-party kernel extensions…
I wonder if Duet Display is getting in the way here. Can you please boot macOS to safe mode and see if the bug is still present when these extensions are disabled?
I’m glad it’s working. That is odd though as I use an Apple MagicMouse (Bluetooth). It’s not a great mouse for Rhino though (I switch to a three-button mouse with a proper scroll wheel when modeling).
On a Macbook pro here and Ctrl Click isn’t working as a Right Click, only in Grasshopper. Works fine with my mouse but sometimes I only have the trackpad…
Apple Intel 64-bit macOS Version 10.15.6 (Build 19G73) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro11,2
Intel Iris Pro OpenGL Engine (OpenGL ver:4.1 INTEL-14.7.8)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 1536 MB
Graphics: Intel Iris Pro
Displays: Color LCD (221dpi 2x)
Graphics processors
Intel Iris Pro (1536 MB)
Color LCD (1440 x 900)
USB devices
Apple: Internal Memory Card Reader
As a quick workaround you can set right-click to be activated when you click the bottom right corner of the trackpad. Maybe that works the same as the right-click of a mouse. It’s in System Preferences -> Trackpad.
Apologies for bringing this back from the dead… I can reliably destroy the ability to right click by moving grasshopper to a different monitor from the main rhino window (which would otherwise be very useful).
To be clear, when I say “right click,” I also mean ctrl+click.
I’m on a macbook pro, so here are the two possibilities:
rhino on built-in monitor + grasshopper on secondary monitor = right click works grasshopper on built-in monitor + rhino on secondary monitor = no right click grasshopper and rhino on built-in monitor = no right click
grasshopper and rhino on secondary monitor = right click works
tl;dr, right click doesn’t work when gh is on the built-in monitor
Just encountered the bug with right click not working in Grasshopper when on secondary monitor (macOS Mojave 10.14.6 ). Not sure but might have been introduced in the latest SRC - 7.5.21082.11002, 2021-03-23.
Just to clarify - Rhino i s running on main monitor, Grasshopper on secondary.
As soon as I drag the Grasshopper window to main monitor it works again.
Please look into it as that’s the main workflow for me and probably many others…
Thanks !
@curtisw Indeed - reinstalled the official RC 7.4.21078.01002, 2021-03-19 and the problem disappeared so it seems that the latest SRC introduced this bug unfortunately…
Hi - I have the dreaded Mac rightclick fail problem also. looks like after installing the latest versions of both RH6 and RH7, I can’t rightclick on any components and get the context menu. empty rhino file, empty grasshopper file. drop any component on and try rightclicking and nothing happens.
I’m running the latest Catalina.
EDIT: just noticed someone mentioned in the comments above it was only failing on their secondary monitor, and indeed, this is the case for me also. if I move the GH window to the main monitor, it works fine.
