I am trying to use ELK (2.2.2) add on for grasshopper.
Theres a special feature in this component where you need to right click the component and “Set feature type” as I am seeing in all the video guided tutorials.
On mac, I have succesfully downloaded the plugin but i cannot access all its features because of the “right click button not working”
A right click in MacOS can usually be done via Ctrl+Click, or you can enable it on a trackpad checking System Preferences > Trackpad > Point & Click > Secondary Click, and using two fingers to tap.
Sorry, my bad. I just tested this out and I didn’t realize “right click not working” means that the menu isn’t showing. Let me dig a bit, there may be something we can do to fix this on our end.
Yup, looks like we can get that one fixed up. The ELK plugin uses a specific way to populate a ComboBox that wasn’t implemented yet. I’ve created RH-59538 to track that issue.
@curtisw
Thanks for fixing the issue!
There is another problem when using the OSM component with Mac. If you right click on the OSM and then left click on ‘Select feature sub-types’ a menu should open to select sub-categories. Unfortunately the menu window does not open. Is there a way to solve this problem as well?
Thanks a lot in advance.
