If I right-click on the display tab, a giant grey bar pops up that covers most of both of my monitors.
Happens with any of the side bar tabs, I think.
Also happens if I left-click or right-click on the options gear to the right of that tab.
Yikes - can you please run SystemInfo and paste the results here?
thanks,
Rhino 6 SR0 2017-11-28 (Rhino WIP, 6.0.17332.10241, Git hash:master @ 9359b47f5eb8d52c08ca047420e2fe6f08347939)
Windows 7 SP1 (Physical RAM: 16Gb)
Quadro K3100M/PCIe/SSE2 (OpenGL ver:4.4.0 NVIDIA 344.75)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.4
Shading Language: 4.40 NVIDIA via Cg compiler
Driver Date: 11-12-2014
Driver Version: 9.18.13.4475
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino WIP\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino WIP\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino WIP\Plug-ins\RhinoRender.rhp “Rhino Render”
C:\Program Files\Rhino WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino WIP\Plug-ins\rdk_ui.rhp “Renderer Development Kit UI”
C:\Program Files\Rhino WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Rhino WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Rhino WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino WIP\Plug-ins\Displacement.rhp “Displacement”
Hi Peter - this is what I’d fix first - let’s see what happens with newer drivers - I’m not sure that’s the cause but we should eliminate that first…
Oh, that’s really old. And windows says it’s up to date. I’ll download the update manually & see what happens.
That did not fix the problem. I also tried it using just one screen and the result was the same.
Durn… I don’t know, I guess we can ask the Panel master @andy if he has seen this or has an idea. Andy- can you look at the clip on the original posting above…? weird, huh?
Are you running the classic window theme? If so, could you try switching to an aero based theme to see if it persists?
I switched to an aero theme from classic, and the problem goes away.
