I was hopeful on the reading the release notes for the latest service release that the annoying “sometimes it works sometimes it doesn’t” right click in the layers panel had been fixed.
However, it’s doesn’t appear to be, at least on my install.
HEre’s what I’m seeing:
1 - Behaves normally (i…e right clicking brings up the context menu.
That will be fine for a while after a launch. However at some point (and I’m not sure exactly what causes it) it fails with either:
a - right click edits the layer name (and based on it SHOULD be bringing down the context menu it shouldn’t compete with “editing”. Maybe a double click to edit or just use the menu but the vast majority of the time you AREN’T editing the layer name but moving objects to it or other menu item stuff. That’s been really inconsistent for some time.
b - ignore the right click completely and does nothing.
Whether it’s a or b is pretty random.
Sometimes, if you do other stuff, or lose app focus and come back, it’ll go back to working again, and I (again) have no idea why, but it’s very much still alive and being annoying.
The other one semi-related to this that’s still alive and kicking and endlessl annoying that I reported both in 7 and 8 is the whole business of the name field in properties.
I name my stuff a LOT. Makes it easier to find via searches, makes it clear what’s being selected when multiple objects are on top of each other, makes the work setf documenting for months later when you have to revisit it.
So this gets used a LOT…
And what’s super annoying is usually, I’ll have one or more objects selected, want to put a name on em and go on with what I’m doing, and invariably I go into the name field, type the name, hit return and chronically forgot that often that does NOT return the focus to the command line, so the next thing I type (which is always a command) ends up renaming the selected objects rather then issuing the command.
One of two things happens at that point:
I catch it, and then have to retype whatever I’d named it after doing a select all and delete in the name field, then very consciously click someplace else to take focus out of the name field.
- OR -
I don’t notice it because I’m not looking at it and click on something else thus committing the edit and in the process misnaming the objects.
My files are littered with literally hundreds of objects named “rect”, “wc”, “trim” and myriads of other rhino commands and aliases.
Would sure be nice to actually get a fix on that one.
Info below:
Rhino 8 SR10 2024-8-13 (Rhino 8, 8.10.24226.13002, Git hash:master @ c36ab43d576d4854b29b091b6b3a38e09decabf5)
License type: Commercial, build 2024-08-13
License details: Cloud Zoo
Apple macOS Version 12.6.1 (Build 21G217) (Physical RAM: 96GB)
Mac Model Identifier: MacPro5,1
Language: en-US (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon RX 580 (8 GB)
LG HDR 4K - Left (3840 x 2160 @ 60.00Hz)
LG HDR 4K - RIght (3840 x 2160 @ 60.00Hz)
GPU Vendor: AMD
USB devices
VIA Labs, Inc. : USB2.0 Hub
ASMT: USB 3.0 Destop HD EP0 Product string
Generic: USB3.0 Card Reader
Broadcom Corp.: Bluetooth USB Host Controller
Kensington: Kensington Slimblade Trackball
3Dconnexion: SpaceMouse Enterprise
Apple, Inc: Apple Keyboard
Bluetooth devices
None
Third party kernel extensions
as.vit9696.Lilu (1.6.2) 264B15BE-8923-3A33-A9F5-8F0FFBB80595
as.vit9696.WhateverGreen (1.6.3) 9599C0FC-6144-3136-854C-C15FFF63706F
com.khronokernel.FeatureUnlock (1.1.2) 46C7C044-AE43-378A-8E50-F24BA68705DA
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_USD.rhp “Export USD” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_E57.rhp “E57 Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_modelio_macos.rhp “Model IO Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Squish.rhp “Squish” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_X.rhp “X Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_STL.rhp “STL Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_STL.rhp “STL Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_Points.rhp “Points Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_X.rhp “X Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/import_Points.rhp “Points Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 8.10.24226.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.10.24226.13002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.10.24226.13002
