Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.19
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 4-11-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.22
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 4-11-2024 (M-D-Y).
- Secondary monitor attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-11-2024
Driver Version: 31.0.15.5222
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\ProgramData\McNeel\Rhinoceros\8.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino8.rhp “Datasmith Exporter” 5.4.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Cephalopod\0.0.3.0\Cephalopod.rhp “Cephalopod” 0.0.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
I’m afraid that’s the new norm for now with the first start after an update. Rhino spends a lot of time loading all the new Python stuff. Other plug-ins might also contribute to the slow startup.
Add to the shortcut through which you start Rhino /stopwatch.
After a startup has completed hit F2 (or run _CommandHistory in case you have rebound F2) to get a listing of timings.
The output looks like this
(0.0000) - Since Last Record = 0.0000 (%0.00) - Create Stopwatch
(0.6850) - Since Last Record = 0.6850 (%8.86) - after create and load AppSettings
(0.6860) - Since Last Record = 0.0010 (%0.01) - before CRhWGLExtensions::InitWGLExtensions()
(0.8870) - Since Last Record = 0.2010 (%2.60) - after CRhWGLExtensions::InitWGLExtensions()
(0.8910) - Since Last Record = 0.0040 (%0.05) - construct CMainFrame
(1.4390) - Since Last Record = 0.5480 (%7.09) - after load CMainFrame
(2.4480) - Since Last Record = 1.0090 (%13.05) - after initialize license manager
(2.4490) - Since Last Record = 0.0010 (%0.01) - after log events
(2.4500) - Since Last Record = 0.0010 (%0.01) - after registering shell file types
(2.4500) - Since Last Record = 0.0000 (%0.00) - before loading of cursor resources
(2.4600) - Since Last Record = 0.0100 (%0.13) - after loading of cursor resources
(2.4980) - Since Last Record = 0.0380 (%0.49) - after RegisterBuiltInCommands()
(2.5260) - Since Last Record = 0.0280 (%0.36) - Pre auto load plugins
(2.5540) - Since Last Record = 0.0280 (%0.36) - Toolbars
(2.5560) - Since Last Record = 0.0020 (%0.03) - RDK:CRhRdkRhinoPlugIn CTOR
(2.5560) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn
(2.5590) - Since Last Record = 0.0030 (%0.04) - RDK:Initialize: start
(2.5590) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default registered properties
(2.5660) - Since Last Record = 0.0070 (%0.09) - RDK:Initialize: after default post effect plug-in factories
(2.5660) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(2.5660) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(2.5750) - Since Last Record = 0.0090 (%0.12) - RDK:Initialize: end
(2.5750) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(2.5750) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(2.5780) - Since Last Record = 0.0030 (%0.04) - RDK:OnLoadPlugIn - end
(2.6290) - Since Last Record = 0.0510 (%0.66) - Renderer Development Kit
(2.7860) - Since Last Record = 0.1570 (%2.03) - Commands
(2.7990) - Since Last Record = 0.0130 (%0.17) - Snapshots
(6.4140) - Since Last Record = 3.6150 (%46.74) - Bongo 3.0
(6.4250) - Since Last Record = 0.0110 (%0.14) - Rhino Render
(6.5120) - Since Last Record = 0.0870 (%1.12) - RDK_EtoUI
(6.5290) - Since Last Record = 0.0170 (%0.22) - MeshCommands
(6.6180) - Since Last Record = 0.0890 (%1.15) - RhinoCycles
(6.6360) - Since Last Record = 0.0180 (%0.23) - 3Dconnexion 3D Mouse
(6.6470) - Since Last Record = 0.0110 (%0.14) - Displacement
(6.6620) - Since Last Record = 0.0150 (%0.19) - SectionTools
(6.7090) - Since Last Record = 0.0470 (%0.61) - BongoEtoUI
(6.7160) - Since Last Record = 0.0070 (%0.09) - HDRLightStudioTexture
(6.7240) - Since Last Record = 0.0080 (%0.10) - SubstanceImporter
(6.7240) - Since Last Record = 0.0000 (%0.00) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.7240) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.7250) - Since Last Record = 0.0010 (%0.01) - after create TabbedDockBarCollection
(6.7250) - Since Last Record = 0.0000 (%0.00) - after load default render engine
(6.7250) - Since Last Record = 0.0000 (%0.00) - after CloseAllDocuments
(6.8630) - Since Last Record = 0.1380 (%1.78) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(6.8640) - Since Last Record = 0.0010 (%0.01) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.0660) - Since Last Record = 0.2020 (%2.61) - Grasshopper
(7.0720) - Since Last Record = 0.0060 (%0.08) - RhiPPI
(7.0720) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.0720) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(7.0720) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(7.4800) - Since Last Record = 0.4080 (%5.28) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(7.4800) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(7.4840) - Since Last Record = 0.0040 (%0.05) - before Process Shell Commands
(7.7280) - Since Last Record = 0.2440 (%3.15) - after Process Shell Commands
(7.7340) - Since Last Record = 0.0060 (%0.08) - CRhStopWatch::ShowReport()
Command: _CommandHistory
I am actually running a couple plugins that may be considered non-standard. That said, they didn’t used to have any negative effect. I’ll list them in the morning, thx
Hey @nathanletwory - you have me intrigued by the /nosplash
Is there anything after that addition that I would need to know in order to add that to my shortcut?
And here’s the stopwatch results. I wasn’t sure what you meant about “run it again” so I just closed Rhino and then started it up again, each time grabbing the stopwatch results. I did that with both a Basic Template, and a Custom Template, and I’ve pasted the results for that 2nd Run for each here. Not sure what’s hanging up the basic template, but there’s a doozy on the custom one!
2nd Run - Basic inches, Feet-Inches Template
(1.2930) - Since Last Record = 1.2930 (%15.57) - after create and load AppSettings
(1.2960) - Since Last Record = 0.0030 (%0.04) - before CRhWGLExtensions::InitWGLExtensions()
(1.6710) - Since Last Record = 0.3750 (%4.52) - after CRhWGLExtensions::InitWGLExtensions()
(1.6820) - Since Last Record = 0.0110 (%0.13) - before Create splash window
(1.6820) - Since Last Record = 0.0000 (%0.00) - after Create splash window
(1.6870) - Since Last Record = 0.0050 (%0.06) - construct CMainFrame
(2.5690) - Since Last Record = 0.8820 (%10.62) - after load CMainFrame
(2.8730) - Since Last Record = 0.3040 (%3.66) - after initialize license manager
(3.2880) - Since Last Record = 0.4150 (%5.00) - after log events
(3.2930) - Since Last Record = 0.0050 (%0.06) - after registering shell file types
(3.2930) - Since Last Record = 0.0000 (%0.00) - before loading of cursor resources
(3.3260) - Since Last Record = 0.0330 (%0.40) - after loading of cursor resources
(3.4050) - Since Last Record = 0.0790 (%0.95) - after RegisterBuiltInCommands()
(3.4890) - Since Last Record = 0.0840 (%1.01) - Pre auto load plugins
(3.5420) - Since Last Record = 0.0530 (%0.64) - Toolbars
(3.5620) - Since Last Record = 0.0200 (%0.24) - RDK:CRhRdkRhinoPlugIn CTOR
(3.5640) - Since Last Record = 0.0020 (%0.02) - RDK:OnLoadPlugIn
(3.5700) - Since Last Record = 0.0060 (%0.07) - RDK:Initialize: start
(3.5700) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default registered properties
(3.5840) - Since Last Record = 0.0140 (%0.17) - RDK:Initialize: after default post effect plug-in factories
(3.5840) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(3.5840) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(3.5990) - Since Last Record = 0.0150 (%0.18) - RDK:Initialize: end
(3.5990) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(3.5990) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(3.6040) - Since Last Record = 0.0050 (%0.06) - RDK:OnLoadPlugIn - end
(3.7460) - Since Last Record = 0.1420 (%1.71) - Renderer Development Kit
(4.0770) - Since Last Record = 0.3310 (%3.99) - Commands
(4.1460) - Since Last Record = 0.0690 (%0.83) - Snapshots
(4.2100) - Since Last Record = 0.0640 (%0.77) - Rhino Render
(4.3720) - Since Last Record = 0.1620 (%1.95) - RDK_EtoUI
(4.4410) - Since Last Record = 0.0690 (%0.83) - MeshCommands
(4.7870) - Since Last Record = 0.3460 (%4.17) - RhinoCycles
(4.8530) - Since Last Record = 0.0660 (%0.79) - 3Dconnexion 3D Mouse
(4.9220) - Since Last Record = 0.0690 (%0.83) - Displacement
(4.9860) - Since Last Record = 0.0640 (%0.77) - SectionTools
(5.5020) - Since Last Record = 0.5160 (%6.21) - Datasmith Exporter
(5.5400) - Since Last Record = 0.0380 (%0.46) - BlockEdit
(5.5600) - Since Last Record = 0.0200 (%0.24) - RhinoPbrMaterial
(5.5860) - Since Last Record = 0.0260 (%0.31) - SubstanceImporter
(5.5860) - Since Last Record = 0.0000 (%0.00) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(5.5860) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(5.5870) - Since Last Record = 0.0010 (%0.01) - after create TabbedDockBarCollection
(5.5880) - Since Last Record = 0.0010 (%0.01) - after load default render engine
(5.5890) - Since Last Record = 0.0010 (%0.01) - after CloseAllDocuments
(5.6690) - Since Last Record = 0.0800 (%0.96) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(5.6700) - Since Last Record = 0.0010 (%0.01) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(6.3770) - Since Last Record = 0.7070 (%8.51) - End of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(6.3770) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(6.3770) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(7.3840) - Since Last Record = 1.0070 (%12.13) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(7.3840) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(7.3870) - Since Last Record = 0.0030 (%0.04) - before Process Shell Commands
(8.2910) - Since Last Record = 0.9040 (%10.89) - after Process Shell Commands
(8.3030) - Since Last Record = 0.0120 (%0.14) - CRhStopWatch::ShowReport()
Command: _SetDimensionLayer
Specify dimension layer options ( UseDimensionLayer=No DimensionLayer= ): _D
Dimension layer name ( List Reset ): Layout::03_Dimensions
Specify dimension layer options ( UseDimensionLayer=Yes DimensionLayer=Layout::03_Dimensions ): _Enter
2nd Run - Custom Template
Loading Legacy Rhino Render, version 1.50, May 28 2024, 15:16:35
Read 2 annotation styles and 7 annotation objects that reference 1 font that is not installed on this device.
Annotation styles referencing a missing font:
AMF_1/4" (48 scale) / Metrostyle Extended [MetrostyleExtended-Regular]
AMF_1/2" (24 scale) / Metrostyle Extended [MetrostyleExtended-Regular]
Missing font:
(1.0560) - Since Last Record = 1.0560 (%5.94) - after create and load AppSettings
(1.0570) - Since Last Record = 0.0010 (%0.01) - before CRhWGLExtensions::InitWGLExtensions()
(1.4050) - Since Last Record = 0.3480 (%1.96) - after CRhWGLExtensions::InitWGLExtensions()
(1.4110) - Since Last Record = 0.0060 (%0.03) - before Create splash window
(1.4120) - Since Last Record = 0.0010 (%0.01) - after Create splash window
(1.4160) - Since Last Record = 0.0040 (%0.02) - construct CMainFrame
(2.2450) - Since Last Record = 0.8290 (%4.66) - after load CMainFrame
(2.5420) - Since Last Record = 0.2970 (%1.67) - after initialize license manager
(3.2490) - Since Last Record = 0.7070 (%3.98) - after log events
(3.2530) - Since Last Record = 0.0040 (%0.02) - after registering shell file types
(3.2530) - Since Last Record = 0.0000 (%0.00) - before loading of cursor resources
(3.2900) - Since Last Record = 0.0370 (%0.21) - after loading of cursor resources
(3.3540) - Since Last Record = 0.0640 (%0.36) - after RegisterBuiltInCommands()
(3.4370) - Since Last Record = 0.0830 (%0.47) - Pre auto load plugins
(3.4860) - Since Last Record = 0.0490 (%0.28) - Toolbars
(3.4930) - Since Last Record = 0.0070 (%0.04) - RDK:CRhRdkRhinoPlugIn CTOR
(3.4950) - Since Last Record = 0.0020 (%0.01) - RDK:OnLoadPlugIn
(3.4980) - Since Last Record = 0.0030 (%0.02) - RDK:Initialize: start
(3.4980) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default registered properties
(3.5110) - Since Last Record = 0.0130 (%0.07) - RDK:Initialize: after default post effect plug-in factories
(3.5110) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(3.5110) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(3.5270) - Since Last Record = 0.0160 (%0.09) - RDK:Initialize: end
(3.5270) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(3.5270) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(3.5310) - Since Last Record = 0.0040 (%0.02) - RDK:OnLoadPlugIn - end
(3.6890) - Since Last Record = 0.1580 (%0.89) - Renderer Development Kit
(4.0190) - Since Last Record = 0.3300 (%1.86) - Commands
(4.0730) - Since Last Record = 0.0540 (%0.30) - Snapshots
(4.1220) - Since Last Record = 0.0490 (%0.28) - Rhino Render
(4.2830) - Since Last Record = 0.1610 (%0.91) - RDK_EtoUI
(4.3450) - Since Last Record = 0.0620 (%0.35) - MeshCommands
(4.6590) - Since Last Record = 0.3140 (%1.77) - RhinoCycles
(4.7220) - Since Last Record = 0.0630 (%0.35) - 3Dconnexion 3D Mouse
(4.7790) - Since Last Record = 0.0570 (%0.32) - Displacement
(4.8400) - Since Last Record = 0.0610 (%0.34) - SectionTools
(5.3600) - Since Last Record = 0.5200 (%2.92) - Datasmith Exporter
(5.4060) - Since Last Record = 0.0460 (%0.26) - BlockEdit
(5.4250) - Since Last Record = 0.0190 (%0.11) - RhinoPbrMaterial
(5.4490) - Since Last Record = 0.0240 (%0.13) - SubstanceImporter
(5.4490) - Since Last Record = 0.0000 (%0.00) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(5.4490) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(5.4500) - Since Last Record = 0.0010 (%0.01) - after create TabbedDockBarCollection
(5.4510) - Since Last Record = 0.0010 (%0.01) - after load default render engine
(5.4530) - Since Last Record = 0.0020 (%0.01) - after CloseAllDocuments
(5.5320) - Since Last Record = 0.0790 (%0.44) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(5.5340) - Since Last Record = 0.0020 (%0.01) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(6.1530) - Since Last Record = 0.6190 (%3.48) - End of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(6.1530) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(6.1530) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(7.1420) - Since Last Record = 0.9890 (%5.56) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(7.1420) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(7.1440) - Since Last Record = 0.0020 (%0.01) - before Process Shell Commands (16.5730) - Since Last Record = 9.4290 (%53.04) - RhinoScript
(16.6380) - Since Last Record = 0.0650 (%0.37) - Rhino Bonus Tools
(16.7090) - Since Last Record = 0.0710 (%0.40) - AnimationTools
(16.7840) - Since Last Record = 0.0750 (%0.42) - Legacy Rhino Render
(17.7640) - Since Last Record = 0.9800 (%5.51) - after Process Shell Commands
(17.7780) - Since Last Record = 0.0140 (%0.08) - CRhStopWatch::ShowReport()
Not really. I use /nosplash because I don’t like the splash screen
I just meant that after adding the stopwatch argument you can Rhino (… again), and see what the results are.
For better comparison you should run twice with the same template. Anyway, as mentioned, first start after an update typically will take time. You can see with the stopwatch what exactly - not that you can do much about it, but it may help you understand. Subsequent starts of Rhino should be faster. Templates shouldn’t matter here much if at all.
Are you able to make heads or tails out of these (above?) There’s definitely a difference between the two templates! Particularly the 9+sec line in Custom Template where I bolded and marked it with some
At the moment I have one start-up command to set my Dimensions to a specific layer.
I should note that this has been my setup for years now, and this is the first time there’s been any problem with the startup times. In fact, just a few months ago, Rhino would open on this Template so fast I couldn’t even click the Splash screen to choose an alternate file to open!
Updated (but not better) results after paring down my template.
Got rid of Startup command
Uninstalled non-essential plugins
Pared down Layers
Deleted all Blocks
Disabled RhinoScript (8.6350 sec)
Disabled RhinoScriptEditor
Pared-down Custom - 1st Run
Read 2 annotation styles that reference 1 font that is not installed on this device.
Missing font:
(1.0080) - Since Last Record = 1.0080 (%5.85) - after create and load AppSettings
(1.0090) - Since Last Record = 0.0010 (%0.01) - before CRhWGLExtensions::InitWGLExtensions()
(1.3720) - Since Last Record = 0.3630 (%2.11) - after CRhWGLExtensions::InitWGLExtensions()
(1.3780) - Since Last Record = 0.0060 (%0.03) - before Create splash window
(1.3780) - Since Last Record = 0.0000 (%0.00) - after Create splash window
(1.4040) - Since Last Record = 0.0260 (%0.15) - construct CMainFrame
(2.2420) - Since Last Record = 0.8380 (%4.86) - after load CMainFrame
(2.5380) - Since Last Record = 0.2960 (%1.72) - after initialize license manager
(4.4910) - Since Last Record = 1.9530 (%11.34) - after log events
(4.4960) - Since Last Record = 0.0050 (%0.03) - after registering shell file types
(4.4960) - Since Last Record = 0.0000 (%0.00) - before loading of cursor resources
(4.5290) - Since Last Record = 0.0330 (%0.19) - after loading of cursor resources
(4.5930) - Since Last Record = 0.0640 (%0.37) - after RegisterBuiltInCommands()
(4.6650) - Since Last Record = 0.0720 (%0.42) - Pre auto load plugins
(4.7050) - Since Last Record = 0.0400 (%0.23) - Toolbars
(4.7100) - Since Last Record = 0.0050 (%0.03) - RDK:CRhRdkRhinoPlugIn CTOR
(4.7110) - Since Last Record = 0.0010 (%0.01) - RDK:OnLoadPlugIn
(4.7200) - Since Last Record = 0.0090 (%0.05) - RDK:Initialize: start
(4.7200) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default registered properties
(4.7330) - Since Last Record = 0.0130 (%0.08) - RDK:Initialize: after default post effect plug-in factories
(4.7330) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(4.7330) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(4.7490) - Since Last Record = 0.0160 (%0.09) - RDK:Initialize: end
(4.7490) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(4.7490) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(4.7530) - Since Last Record = 0.0040 (%0.02) - RDK:OnLoadPlugIn - end
(4.8560) - Since Last Record = 0.1030 (%0.60) - Renderer Development Kit
(5.1350) - Since Last Record = 0.2790 (%1.62) - Commands
(5.1900) - Since Last Record = 0.0550 (%0.32) - Snapshots
(5.2400) - Since Last Record = 0.0500 (%0.29) - Rhino Render
(5.3900) - Since Last Record = 0.1500 (%0.87) - RDK_EtoUI
(5.4470) - Since Last Record = 0.0570 (%0.33) - MeshCommands
(5.7120) - Since Last Record = 0.2650 (%1.54) - RhinoCycles
(5.7750) - Since Last Record = 0.0630 (%0.37) - 3Dconnexion 3D Mouse
(5.8190) - Since Last Record = 0.0440 (%0.26) - Displacement
(5.8740) - Since Last Record = 0.0550 (%0.32) - SectionTools
(6.3600) - Since Last Record = 0.4860 (%2.82) - Datasmith Exporter
(6.3910) - Since Last Record = 0.0310 (%0.18) - BlockEdit
(6.4060) - Since Last Record = 0.0150 (%0.09) - RhinoPbrMaterial
(6.4260) - Since Last Record = 0.0200 (%0.12) - SubstanceImporter
(6.4260) - Since Last Record = 0.0000 (%0.00) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.4260) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.4270) - Since Last Record = 0.0010 (%0.01) - after create TabbedDockBarCollection
(6.4280) - Since Last Record = 0.0010 (%0.01) - after load default render engine
(6.4310) - Since Last Record = 0.0030 (%0.02) - after CloseAllDocuments
(6.5060) - Since Last Record = 0.0750 (%0.44) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(6.5070) - Since Last Record = 0.0010 (%0.01) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.2030) - Since Last Record = 0.6960 (%4.04) - End of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.2030) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(7.2030) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(8.1150) - Since Last Record = 0.9120 (%5.29) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(8.1150) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(8.1170) - Since Last Record = 0.0020 (%0.01) - before Process Shell Commands
(16.7520) - Since Last Record = 8.6350 (%50.12) - Rhino Bonus Tools
(16.8000) - Since Last Record = 0.0480 (%0.28) - AnimationTools
(16.8620) - Since Last Record = 0.0620 (%0.36) - Legacy Rhino Render
(17.2150) - Since Last Record = 0.3530 (%2.05) - after Process Shell Commands
(17.2270) - Since Last Record = 0.0120 (%0.07) - CRhStopWatch::ShowReport()
Command: _Options
Next up, Disabled:
Disabled RhinoBonusTools+others
Missing font:
(0.9800) - Since Last Record = 0.9800 (%5.44) - after create and load AppSettings
(0.9810) - Since Last Record = 0.0010 (%0.01) - before CRhWGLExtensions::InitWGLExtensions()
(1.3110) - Since Last Record = 0.3300 (%1.83) - after CRhWGLExtensions::InitWGLExtensions()
(1.3170) - Since Last Record = 0.0060 (%0.03) - before Create splash window
(1.3170) - Since Last Record = 0.0000 (%0.00) - after Create splash window
(1.3210) - Since Last Record = 0.0040 (%0.02) - construct CMainFrame
(2.1700) - Since Last Record = 0.8490 (%4.72) - after load CMainFrame
(2.4620) - Since Last Record = 0.2920 (%1.62) - after initialize license manager
(5.1280) - Since Last Record = 2.6660 (%14.81) - after log events
(5.1310) - Since Last Record = 0.0030 (%0.02) - after registering shell file types
(5.1310) - Since Last Record = 0.0000 (%0.00) - before loading of cursor resources
(5.1500) - Since Last Record = 0.0190 (%0.11) - after loading of cursor resources
(5.1980) - Since Last Record = 0.0480 (%0.27) - after RegisterBuiltInCommands()
(5.4470) - Since Last Record = 0.2490 (%1.38) - Pre auto load plugins
(5.4990) - Since Last Record = 0.0520 (%0.29) - Toolbars
(5.5040) - Since Last Record = 0.0050 (%0.03) - RDK:CRhRdkRhinoPlugIn CTOR
(5.5060) - Since Last Record = 0.0020 (%0.01) - RDK:OnLoadPlugIn
(5.5140) - Since Last Record = 0.0080 (%0.04) - RDK:Initialize: start
(5.5140) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default registered properties
(5.5280) - Since Last Record = 0.0140 (%0.08) - RDK:Initialize: after default post effect plug-in factories
(5.5280) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(5.5280) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(5.5480) - Since Last Record = 0.0200 (%0.11) - RDK:Initialize: end
(5.5480) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(5.5480) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(5.5560) - Since Last Record = 0.0080 (%0.04) - RDK:OnLoadPlugIn - end
(5.6810) - Since Last Record = 0.1250 (%0.69) - Renderer Development Kit
(5.9710) - Since Last Record = 0.2900 (%1.61) - Commands
(6.0130) - Since Last Record = 0.0420 (%0.23) - Snapshots
(6.0540) - Since Last Record = 0.0410 (%0.23) - Rhino Render
(6.1930) - Since Last Record = 0.1390 (%0.77) - RDK_EtoUI
(6.2520) - Since Last Record = 0.0590 (%0.33) - MeshCommands
(6.5470) - Since Last Record = 0.2950 (%1.64) - RhinoCycles
(6.6040) - Since Last Record = 0.0570 (%0.32) - 3Dconnexion 3D Mouse
(6.6480) - Since Last Record = 0.0440 (%0.24) - Displacement
(6.7280) - Since Last Record = 0.0800 (%0.44) - SectionTools
(7.2580) - Since Last Record = 0.5300 (%2.94) - Datasmith Exporter
(7.2900) - Since Last Record = 0.0320 (%0.18) - BlockEdit
(7.3050) - Since Last Record = 0.0150 (%0.08) - RhinoPbrMaterial
(7.3280) - Since Last Record = 0.0230 (%0.13) - SubstanceImporter
(7.3280) - Since Last Record = 0.0000 (%0.00) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(7.3280) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(7.3280) - Since Last Record = 0.0000 (%0.00) - after create TabbedDockBarCollection
(7.3290) - Since Last Record = 0.0010 (%0.01) - after load default render engine
(7.3450) - Since Last Record = 0.0160 (%0.09) - after CloseAllDocuments
(7.4490) - Since Last Record = 0.1040 (%0.58) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(7.4500) - Since Last Record = 0.0010 (%0.01) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(8.2980) - Since Last Record = 0.8480 (%4.71) - End of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(8.2980) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(8.2980) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(9.1190) - Since Last Record = 0.8210 (%4.56) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(9.1190) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(9.1210) - Since Last Record = 0.0020 (%0.01) - before Process Shell Commands
(17.6140) - Since Last Record = 8.4930 (%47.18) - AnimationTools
(17.9890) - Since Last Record = 0.3750 (%2.08) - after Process Shell Commands
(18.0010) - Since Last Record = 0.0120 (%0.07) - CRhStopWatch::ShowReport()
Command: _Options
Sooo…Now it’s AnimationTools that’s over 8sec. Which mean the culprit is…Process Shell Commands!! I have no idea what I do with that information
So I disable AnimationTools, and now the “after Process Shell Commands” is 9secs.
Disabled AnimationTools
Missing font:
(1.1820) - Since Last Record = 1.1820 (%6.67) - after create and load AppSettings
(1.1840) - Since Last Record = 0.0020 (%0.01) - before CRhWGLExtensions::InitWGLExtensions()
(1.5450) - Since Last Record = 0.3610 (%2.04) - after CRhWGLExtensions::InitWGLExtensions()
(1.5500) - Since Last Record = 0.0050 (%0.03) - before Create splash window
(1.5510) - Since Last Record = 0.0010 (%0.01) - after Create splash window
(1.5550) - Since Last Record = 0.0040 (%0.02) - construct CMainFrame
(2.5500) - Since Last Record = 0.9950 (%5.62) - after load CMainFrame
(2.8560) - Since Last Record = 0.3060 (%1.73) - after initialize license manager
(4.9290) - Since Last Record = 2.0730 (%11.70) - after log events
(4.9330) - Since Last Record = 0.0040 (%0.02) - after registering shell file types
(4.9330) - Since Last Record = 0.0000 (%0.00) - before loading of cursor resources
(4.9530) - Since Last Record = 0.0200 (%0.11) - after loading of cursor resources
(5.0470) - Since Last Record = 0.0940 (%0.53) - after RegisterBuiltInCommands()
(5.1220) - Since Last Record = 0.0750 (%0.42) - Pre auto load plugins
(5.1750) - Since Last Record = 0.0530 (%0.30) - Toolbars
(5.1840) - Since Last Record = 0.0090 (%0.05) - RDK:CRhRdkRhinoPlugIn CTOR
(5.1860) - Since Last Record = 0.0020 (%0.01) - RDK:OnLoadPlugIn
(5.1970) - Since Last Record = 0.0110 (%0.06) - RDK:Initialize: start
(5.1970) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after default registered properties
(5.2110) - Since Last Record = 0.0140 (%0.08) - RDK:Initialize: after default post effect plug-in factories
(5.2110) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after adding internal extensions
(5.2110) - Since Last Record = 0.0000 (%0.00) - RDK:Initialize: after conduits
(5.2270) - Since Last Record = 0.0160 (%0.09) - RDK:Initialize: end
(5.2270) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK Initialize
(5.2270) - Since Last Record = 0.0000 (%0.00) - RDK:OnLoadPlugIn: after RDK OnLoadRhinoPlugIn
(5.2310) - Since Last Record = 0.0040 (%0.02) - RDK:OnLoadPlugIn - end
(5.3420) - Since Last Record = 0.1110 (%0.63) - Renderer Development Kit
(5.6400) - Since Last Record = 0.2980 (%1.68) - Commands
(5.6900) - Since Last Record = 0.0500 (%0.28) - Snapshots
(5.7360) - Since Last Record = 0.0460 (%0.26) - Rhino Render
(5.8800) - Since Last Record = 0.1440 (%0.81) - RDK_EtoUI
(5.9380) - Since Last Record = 0.0580 (%0.33) - MeshCommands
(6.2120) - Since Last Record = 0.2740 (%1.55) - RhinoCycles
(6.2700) - Since Last Record = 0.0580 (%0.33) - 3Dconnexion 3D Mouse
(6.3140) - Since Last Record = 0.0440 (%0.25) - Displacement
(6.3720) - Since Last Record = 0.0580 (%0.33) - SectionTools
(6.8510) - Since Last Record = 0.4790 (%2.70) - Datasmith Exporter
(6.8880) - Since Last Record = 0.0370 (%0.21) - BlockEdit
(6.9030) - Since Last Record = 0.0150 (%0.08) - RhinoPbrMaterial
(6.9240) - Since Last Record = 0.0210 (%0.12) - SubstanceImporter
(6.9240) - Since Last Record = 0.0000 (%0.00) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.9240) - Since Last Record = 0.0000 (%0.00) - End of C# Rhino.UI.TabPanels.NamedCallbacks.RestoreTabPanelCollections
(6.9250) - Since Last Record = 0.0010 (%0.01) - after create TabbedDockBarCollection
(6.9260) - Since Last Record = 0.0010 (%0.01) - after load default render engine
(6.9280) - Since Last Record = 0.0020 (%0.01) - after CloseAllDocuments
(7.0150) - Since Last Record = 0.0870 (%0.49) - before LoadToolBarsAndRestoreDockBarPositionAndStates
(7.0170) - Since Last Record = 0.0020 (%0.01) - Start of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.7430) - Since Last Record = 0.7260 (%4.10) - End of C# Rhino.UI.TabPanels.NamedCallbacks.LoadInitialToolBars
(7.7430) - Since Last Record = 0.0000 (%0.00) - after m_pCallbacks->LoadToolBarFiles
(7.7430) - Since Last Record = 0.0000 (%0.00) - after RunLoadToolbars
(8.6240) - Since Last Record = 0.8810 (%4.97) - after RunPostLoadToolBarsAndRestoreDockBarPositionAndStates
(8.6240) - Since Last Record = 0.0000 (%0.00) - after LoadToolBarsAndRestoreDockBarPositionAndStates
(8.6260) - Since Last Record = 0.0020 (%0.01) - before Process Shell Commands
(17.6990) - Since Last Record = 9.0730 (%51.22) - after Process Shell Commands
(17.7140) - Since Last Record = 0.0150 (%0.08) - CRhStopWatch::ShowReport()
So no matter what I take out, whatever fills that certain slot takes around 9secs.
Thanks for uploading the video. It appears that you are experiencing an unresponsive GUI after Rhino has started as evidenced by the stopwatch results showing.
I’m not sure what is going on there, maybe @curtisw has a better idea there.
I can certainly replicate the issue with that template, and for some reason it’s taking all the time reading the bitmap table from the 3dm, and a good portion of that trying to find files…
I was actually in the middle of rebuilding my toolbars from the ground up in the Default RUI (or whatever we’re calling it) when I lost everything, then had to quickly get up and running for the day, so I brought my old Toolbar back in from a separate RUI. Hope this helps the process of figuring this out.
Your template file contains many (63) “bitmap table entries”, which reference folders on your local disks (C:, D:, E:, G:, and Z:), and some contain paths to other user account folders on your disk, as well as folders on some network drive/machine (the name I will leave out), this can compound things when Rhino is loading a .3dm file…
When Rhino encounters a “bitmap table entry”, it first tries to locate the file on your disk based on where the .3dm file was loaded (note: It does a full sub-folder search), if that fails, it then takes a look at the “referenced” location of the bitmap (the place where the file was originally loaded when placed in the document), if that fails, then it finally uses the version found in the bitmap table.
So, depending on where the 3dm file is loaded, and whether or not the bitmap files exist on disk, this can be fast or it can take some time, especially if the referenced files are on some network drive.
The first thing I would try is to place the template file in a folder that has no sub-folders, that will at least prevent Rhino from doing unnecessary searches in other folders. But I would really go through and make sure that all of the bitmap table entries are things you want, use, and exist somewhere on your local drive (and account), otherwise, searches can take an undetermined amount of time.
