RhinoCore.dll could not be loaded
did anyone tried this fix?
same question. is there a solution for that?
i just downloaded Rhino 8 for testing. i get the same error.
otherwise i guess that’s it for me already with Rhino.
How do you get the cert? It said This certificate cannot be verified to a trusted certificate authority.
Sorry for late reply for all of you. After this issue, I installed the window again and change my user name in to english. I think this problem occured because of cjk languages in the directory of rhino files. If you are having a trouble similar to me, I highly recommend you to change your user name in english.
Hello everyone,
I have the same problem with the latest Rhino 8.8 update / Win 11Pro 23H2 latest update
After updating the system, either v.7 or v.8 will not start…
An **
Screenshot 2024-06-19 163853
**" pop-up appears while I try to start v.8, but nothing happens.
I have tried starting Rhino in safe mode, tried the Windows ā€œapp repairā€ option for Rhino, reinstalled both versions… unfortunately all to no success.
Does anyone know the solution to the problem?
Thanks in advance,
Marco
This may help people who run into this again:
https://wiki.mcneel.com/rhino/rhinocore-dll-could-not-be-loaded
Grazie io ho risolto…come mi hai indicato…grazie
this is the actual solution for me. thank you
Hey All tryng to install Rhino on my home pc, getting this
none of fixes above work.
downloaded installer twice, wiped and reinstalled .net etc etc.
version is rhino_en-us_8.31.26126.13431
EDIT: FIXED:
I manually uninstalled every single VC redist I had, as one of them was causing the below installer to fail with ā€œthis is already installedā€ then reinstalled the below one, then it ran.
