Rhino is stuck on preparing plugins for first use.
Launched Rhino in Safe mode, disabled all plugins (including the ones that ship with Rhino)
Reset Rhino options to default. (used an .ini with default options)
What should my next step be?
Sorry forgot to add:
My graphics is nvidia RTX, latest driver available.
I’ll assume you rebooted after the Windows update.
Look in Windows’ Check for Updates in “View Update History” to see if there are any failed updates that did not succeed with a subsequent attempt.
Pay particular attention to anything related to .NET.
The update log did not have any failed updates but a new check for updates fetched “Cumulative Update Preview for .NET Framework 3.5 and 4.8 for Windows 10”
Pascal, given to the hint you provided, I unistalled Pavetool from Logis3D and Rhino loaded just fine.
I m going to install it again to see if it Rhino will still load.
I will keep you posted.
Thanks !
Yep, Logis3D plugin installed and loads on demand now.
Thanks again for everybody’s help !
Is there any simple function to restore loading needed plugins on startup, or I should do it on a case by case basis?
