Rhino 8 is no longer opening for me. Rhino 7 opened just fine. I had 8.9 and it would not work. I uninstalled rhino 8 and reinstalled the latest rhino 8 but it still will not work. The following is the crash report I get:
[ERROR] FATAL UNHANDLED EXCEPTION: System.IO.FileNotFoundException: Could not load file or assembly ‘Microsoft.Web.WebView2.Core, Version=1.0.1938.49, Culture=neutral, PublicKeyToken=2a8ab48044d2601e’. The system cannot find the file specified.
File name: ‘Microsoft.Web.WebView2.Core, Version=1.0.1938.49, Culture=neutral, PublicKeyToken=2a8ab48044d2601e’
at RhinoWindows.Runtime.EtoStyles.Apply(Platform platform)
at RhinoWindows.Runtime.Initialization.Start(String s)
at dotnetstart.DotNetInitialization.InitializeRhino(String args)
at dotnetstart.DotNetInitialization.Start(String args)
at dotnetstart.Program.Start(IntPtr arg, Int32 argLength)
[END ERROR]
Any ideas what may be causing Rhino 8 to not work? Is there a way to get my Rhino 8 files to Rhino 7 until Rhino 8 works again?
Thanks for the update, this has been happening to a small set of users after the October Windows update. I’ve added this thread to the bug report, when more information becomes available we can let you know. Great that we got you going but its not a fix per say, more of a bandaid.
I have the same issue here.
I just updated Rhino 8 to 8.14 today, and I get the same issue with Webview2 not found.
It was all fine with the older version of Rhino 8, but I don’t remember what exact version I was using.
Here is a screenshot that I tried to debug a plugin with the new Rhino 8.14, hope this helps.
