RhinoCommon API changes document
Hi, just wanted to ask if there are any plans on expanding this document.
Thanks.
Hi @gabor.konstanzer,
Not at this time, as there really has a been any demand for this. But we might be able to, if needed.
The changes were document in the weekly WIP build logs (on Serengeti). It may be possible to pull all these together.
In reality, not much has changed in RhinoCommon. There is, however, quite a bit of new stuff.
– Dale
Pretty big numbers, but i’m trying to migrate my plugin to R6 and since then i encountered changes with Panel, and Doc control. Which is not trivial what has changed exactly so i think it could be useful.
You shouldn’t have to make changes. Do you recall what you had to change?
