Rhino8 won't run after installation on MacBook Air
Hi everyone,
I have upgraded to Rhino 8 from version 7 today, and now the app won’t open. I get a message saying that rhino8 can’t open. I have reinstalled the app and rebooted as well and check system requirements and compatible OS version. Everything seems fine. I have also checked the “Privacy & Security” settings in case I need to give Rhino permission to my system, but it doesn’t show up there.
(Macbook Air M2, Sequoia 15.2, 16GB RAM)
Anyone had any similar issues?
Thanks for the help Patrik.
Hi Patrik -
Which version of Rhino 8 are you trying to install?
In Rhino 7, please run the SystemInfo command and copy-paste the output here.
Hi Wim,
I have installed 8.15.25013.
See systemInfo below.
Thanks,
Patrik
Rhino 7 SR37 2024-4-16 (Rhino 7, 7.37.24107.15002, Git hash:master @ d2e42f70b9d3aa58f6053e2998a0db2abcd7555b)
License type: Commercial, build 2024-04-16
Apple macOS Version 15.2 (Build 24C101) (Physical RAM: 16Gb)
Rhino is running in Rosetta2 on Apple Silicon
Mac Model Identifier: Mac14,2
Language: sv-SE (MacOS default)
Apple M2 (OpenGL ver:4.1 Metal - 89.3)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 10922 MB
Graphics: Apple M2
Displays: Unknown (257dpi 2x), Unknown (81dpi 1x)
Graphics processors
Apple M2
Color LCD (1470 x 956 @ 60.00Hz)
DELL U2724DE (1920 x 1080 @ 120.00Hz)
USB devices
Realtek: USB 10/100/1G/2.5G LAN
Generic: 4-Port USB 3.0 Hub
Realtek: USB2.0 HID
Dell Computer Corp: Dell Universal Receiver
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswift_Builtin_float.dylib
/usr/lib/swift/libswift_errno.dylib
/usr/lib/swift/libswift_math.dylib
/usr/lib/swift/libswift_signal.dylib
/usr/lib/swift/libswift_stdio.dylib
/usr/lib/swift/libswift_time.dylib
/usr/lib/swift/libswiftsys_time.dylib
/usr/lib/swift/libswiftunistd.dylib
/usr/lib/swift/libswiftDistributed.dylib
/usr/lib/swift/libswiftMLCompute.dylib
/usr/lib/swift/libswiftSynchronization.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftSwiftOnoneSupport.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftSafariServices.dylib
/usr/lib/swift/libswiftSpatial.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftAppleArchive.dylib
/usr/lib/swift/libswiftDataDetection.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftPassKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.37.24107.15002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.37.24107.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.37.24107.15002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.37.24107.15002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.37.24107.1002
Hi Wim,
Did you get a chance to have a look at my issue?
Thanks,
Patrik
Hej Patrik -
Can you post a screenshot of that message?
What happens when you only use the laptop’s screen and disconnect anything else?
Hi Wim, I downloaded a newer version from your site and it works now.
Thanks for the help.
Patrik
