I just bought a new macbook pro and now realise Rhino won’t open my files due to the M2 chip…
This is a serious and expensive shakeup to my workflow, Are there any specific dates on when Rhino 8 will be released to rectify the issue?
Thanks.
Thanks.
M2 Silicon should open the file just fine. I’m using M1 here and all works just fine.
On M2 here and Rhino 7 work as expected as it was on M1. A bit slow on really large files but still good performances compared to a low/medium Win equivalent.
Make sure your macOS and Rhino are updated to the latest.
If that still doesn’t work, run the Rhino SystemInfo command and post the results.
Thanks
Hi, I have encountered a similar issue. I recently bought an M2 pro and the files will open but when I put them in render mode the program goes to “non responsive” and crashes. I have the latest updates both from Mac and rhino. Any ideas what the issue could be?
Kind regards
Malin
Hej Malin -
Did you create those models yourself previously or did you get them from someone else?
Please run the Rhino SystemInfo command and copy-paste the result here.
I have not made them from scratch myself. I’ve received them from a coworker.
Hej -
That’s good to know, thanks.
Another question about M2 Mac & Rhino,
How come it simple flies of 50mb lag so much on the new Apple Silicon despite plenty of available CPU and RAM? This is both on Rhino 7 and 8 WIP?
Hi Marcello -
With the latest optimizations in Rhino 8, that probably shouldn’t be the case.
Can you post (1) a 3dm sample that we can test, and (2) the output of the Rhino SystemInfo command?
