Hi there,
I can’t find how to make Rhino 8 work on my mac. It crashes as soon as I start using any tools.
I’ve looked at some of the discussions around, none helped so far.
If you can help that would be great. Cheers !
Hi there,
are you able to start Rhino? If so, can you run _SystemInfo in Rhino and post back the results?
Thank you, here it is :
Rhino 8 SR22 2025-8-5 (Rhino 8, 8.22.25217.12452, Git hash:master @ 96429e6361004c775cd83973f2148f3943b5e512)
License type: Commercial, build 2025-08-05
License details: Cloud Zoo
Apple macOS Version 14.7 (Build 23H124) (Physical RAM: 32GB)
Mac Model Identifier: iMac17,1
Language: en
.NET 8.0.14
Metal GPU Family Apple 0
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
AMD Radeon R9 M395X (4 GB)
iMac (2560 x 1440)
GPU Vendor: AMD
USB devices
Broadcom Corp.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Logitech: USB Optical Mouse
Bluetooth devices
None
Third party kernel extensions
as.vit9696.Lilu (1.7.0) 276C35BC-B576-3049-AF11-4E11E8EBE459
as.vit9696.RestrictEvents (1.1.5) 7B679FDE-3DCE-37E1-B992-31F11D03E4D7
com.khronokernel.AutoPkgInstaller (1.0.4) 826F8E17-D733-3251-9174-9B8AD5944EF1
com.khronokernel.RSRHelper (1.0.2) 1B59F406-0AB5-3C8C-8A37-6F80BB772598
as.lvs1974.AirportBrcmFixup (2.1.9) 3787F422-FE69-3E82-95F6-BE1B30F39EFD
com.dhinakg.AMFIPass (1.4.1) 7DF1CDFC-7EFE-3D82-A3A2-7DACE8B1D097
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftFoundation.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.22.25217.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.22.25217.12452
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.22.25217.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.22.25217.12452
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.22.25217.12452
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.22.25217.12452
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.22.25217.12452
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.22.25217.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.22.25217.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.22.25217.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.22.25217.12452
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.22.25217.12452
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.22.25217.12452
Also fyi : I’ve posted a crash report.
Did you try 8.23 SRC yet? If not that might be worth trying first
Is that the last update ? not sure to understand what SRC means … I’m up to vers. 8.22 at the moment. I have no access to another update, as far as I can see it.
8.23 SRC is the service release candidate. But never mind this, no need to try
@Jérémie_Waechter a developer is looking into it
RH-88915 Rhino crash Metal related
Hi ! I was away for few days.
I’ve looked into the link you shared, but didn’t seem like any solution was found to my problem. Am I getting this straight ?
Thank you.
Hi Jérémie -
You were sent a link to a in-house built with a test command to run. I don’t see your answer on the result thereof.
Thank you, sorry I missed something, it took me few reads to get what it means, not used to that stuff.
Anyway, i just tried the command “TestCoalesceProcessing” as proposed, and nothing happens. The command is unknown …
I’ve sent you a link in pm. Did you test in there? The command will not run in current service release, since it doesn’t exist in this service release.
Thanks.
So I installed the build you shared and run the command TestCoalesceProcessing > the result indicated “Coalesce preprocessing is disabled”
Contrary to previous version, I managed to build several box and start playing a bit. But crash occured when I tried to change apparence from wireframe to something else.
I shared the crash report.
Do you need other information from me ?
Thanks for testing, I’ve reopened the issue
