trying to use V8 again.
I keep thinking things are not spot on, I move a line, it snaps to another, (left to right direction) yet its not covering it, its above and as I zoom in its then below, then a bit more zoom and its above.
Lines are not ON x axis or Y axis. yet I moved them or so I thought to 0,0.
I am forever zooming in to see if they are on top of other lines.
I take a not quite horiz line and move it to snap to a hrz line then rotate it to be on the horiz line with centre at the intersect. yet its then seen above it, I then think the end of the line wasnt on the other one to start with. More zooming and checking , yet it then appears to be ok, until I zoom out.
never ever had this in V5, draw a line over another and it looked like it was. Never any doubt in the mind.
Its most unsettling. coming from V5 , making me feel il, sea sick !
Its NOT CAD.
lines are not down datum but a pixel left or right, zoom in and they move left or right, why dont they appear over the line ?
I will try, but I also find screen shots DONT show it as it looks, strange as that may sound.
I will start with one earlier today where it was sharp then fuzzy then sharp then fuzzy, it was a vertical line. I then had to save as V5, open it in V5, copy paste the screen into pshop, and the grid was a slightly different size, but scale that and one ruins the actual appearance. The magnification isnt the same between v5 and v8, its important to show it as it appears, so leave the magnification well alone.
Fiddling around doint screen captures and placing into pshop etc takes time, this can stop any work I am trying to do, I will grab examples as I go along, if time allows.
I saw a slight off from vert line was a very different sharp then soft then sharp then soft in V8, so had to see what V5, , that never had it like that, showed, and its there but much less. looks just a standard lune by comparison.
VIEW THESE USING CS6 ACTUAL PIXELS, OR Pshop 2025 100% using the view menu at top of screen.
this one the ants on a line from project to mesh. already mentioned and until V8 fixed, need to change the lines to degree2. V5 was ok.
