Rhino8 Button ToolBar
if I click on edit toolbar button and delete a button, in the toolbar edit the button is removed, while in the toolbar the button is still visible. To update the toolbar you need to restart Rhino.
4Immagine 5Immagine 3Immagine
I hope that the report will be appreciated even if it is a marginal issue.
2Immagine
I would also add that if you close the Container by clicking on the “X” the check remains in the listbox,
in this case you have to close the Container Manager and then reopen it
Hello- that one is on the pile, thanks.
RH-78350 Removing a new Toolbar button does not work
RH-78350 is fixed in Rhino 8 Service Release 2
ok thanks @brian @pascal :+1:
