Rhino7 MAC unable to print nor save to pdf
Hello, when trying to print or save to PDF through the Print command, Rhino throws the following :
Screen Shot 2022-01-06 at 17.11.32
Please fix this as well, these basics commands are crucial for work ! I reported yesterday as well that Rhino is crashing after putting a component on Gh Canvas…
With many thanks and looking forward for a quick fix update…
System info is here :
Rhino 7 SR14 2022-1-4 (Rhino 7, 7.14.22004.01002, Git hash:master @ e3d354475c9d642213575609786a4b35ea48ca22)
License type: Educational, build 2022-01-04
License details: Cloud Zoo
Apple macOS Version 12.1 (Build 21C52) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro15,1
Language: en-JP (MacOS default)
AMD Radeon Pro 560X OpenGL Engine (OpenGL ver:4.1 ATI-4.7.101)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: Radeon Pro 560X
Displays: Color LCD (258dpi 2x), HP Z23n G2 (96dpi 1x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
Radeon Pro 560X (4 GB)
Color LCD (1680 x 1050)
HP Z23n G2 (1920 x 1080 @ 60.00Hz)
USB devices
MOSART Semi.: 2.4G Wireless Mouse
Apple Inc.: USB-C Digital AV Multiport Adapter
Apple Inc.: USB3.0 Hub
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ProRender/1.0.0.6/ProRender.Mac.V7.rhp “ProRender” 1.0.0.6
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/packages/7.0/AMDDenoiser/0.5.0/AMDDenoiser.Mac.rhp “AMDDenoiser.Mac” 1.0.0.0
/Users/ghalibouayad/Library/Application Support/McNeel/Rhinoceros/packages/7.0/Bullant/1.5.11.0/bullant.rhp “bullant” 1.5.11.0
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.14.22004.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.14.22004.1002
Regards,
Hi Ghali -
To make PDF files from Rhino on macOS, please use either Export or ExportAll. That will use the Rhino PDF routines that we control and can potentially fix.
Hi Wim, thank you for your feedback. First time I use export to generate a PDF, however it works so very grateful ! However, PDF through print command used to work perfectly…would be nice to keep a functioning command…
Ghali,
Does the print command fail when attempting to print a model with a single curve in it? I’m trying to determine if this is a model specific problem
Hello @stevebaer, the command is throwing the same error also on a virgin blank file using 1 single line. I tried to several files that used to work perfectly before posting.
I hope this helps figure the origin of this.
Thanks
