I have a problem with printing a PDF in Rhino for Mac. A problem that has persisted since the update to macOS Ventura is that when I press the PDF-bottom in the print window a new windows appears that I have to save in. The initial print window is greyed out and I’m unable to close it. I can only move it. For every time I save a PDF a grey window will appear. The only way to get rid of them is to restart Rhino.
A new problem with macOS Sonoma is that when try to reposition the view by selecting Window and Set, Rhino will print on the printer. Mind that I haven’t pressed Print.
When I have saved the PDF with the usual problem with greyed Windows and I try to close the Print Window, Rhino will unexpectedly crash.
Are these problems you are aware of and know how to fix?
