Rhino7 crashes on startup, plug-in error
Hi all,
This morning, after a Rhino update, I can not start my Rhino anymore.
At startup, the usual Rhino splash screen comes up, then I have this message error that pops up and disappears, which doesn’t allow me to click on the Details button. I do not know which plug-in is causing the problem as I haven’t installed anything new recently.
I can start in safe mode but do not know what plug-in to disable.
Has anyone run into this issue yet?
Thanks in advance for the help!
Hi Eliott, Can you start Rhino in Safe Mode and post the results of SystemInfo in the Rhino Command line?
Thanks
Hi Japhy,
Find below the print of SystemInfo from the Safe Mode
Rhino 7 SR23 2022-10-9 (Rhino 7, 7.23.22282.13001, Git hash:master @ a931168ca9426920ae6aa97218710b662f17fc39)
License type: Educational Lab License, build 2022-10-09
License details: Cloud Zoo
Windows 10 (10.0.19044 SR0.0) or greater (Physical RAM: 32Gb)
Computer platform: LAPTOP  - Unplugged [100% battery remaining] ~234 minutes left
  Primary display and OpenGL: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 8-4-2022 (M-D-Y). OpenGL Ver: (null)
        - Windows Main Display is laptop's integrated screen or built-in port
Secondary graphics devices.
  NVIDIA RTX A2000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 7-12-2021 (M-D-Y).
        - This device is not being used
ATTENTION:
  Safe Mode is enabled. Graphics device usage and OpenGL information cannot be collected.
OpenGL Settings
  Safe mode: On
  Graphics level being used: OpenGL (null) (primary GPU's maximum)
  Anti-alias mode: 4x
  Mip Map Filtering: Linear
  Vendor Name: Unknown
  Render version: (null)
  Shading Language: (null)
  Driver Date: 8-4-2022
  Driver Version: 31.0.101.3358
  Maximum Texture size: n/a
  Z-Buffer depth: n/a
  Maximum Viewport size: 16777472 x 16777217
  Total Video Memory: 1 GB
  C:\Program Files\Rhino 7\Plug-ins\Commands.rhp	"Commands"	7.23.22282.13001
  C:\Program Files\Rhino 7\Plug-ins\rdk.rhp	"Renderer Development Kit"
  C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp	"Toolbars"	7.23.22282.13001
Thanks Eliott, nothing unusual there.
Can you expand and provide the Details of the Plugin error? Thanks
Unfortunately, when this window shows up I cannot click on its button and as described in the initial post it closes itself.
Hi @Eliott_Sounigo,
This stands out:
OpenGL Settings
  Safe mode: On
  Anti-alias mode: 4x
  Z-Buffer depth: n/a
Rhino is not using your RTX video. You might consider grabbing an updated NVIDIA driver and install it.
– Dale
Thanks it fixed it!
