{Rhino7-Crash} «TDR has been detected» | My solution through NVIDIA-Settings
I leave it here in case someone is looking for a solution to a similar problem. Before posting, I searched for similar threads on the forum. I only found topics related to Rhino 6 or 5
Description
Rhino 7 crash after program start on Windows 8.1 with Quadro 600 graphics card.
The Error-Message is “A TDR has been detected. The application must close. Error code 7
08
…and then a link to the NVIDIA page
On the NVIDIA page it is recommended:
1. “Reduce the graphics workload if possible, such as by rendering to a lower resolution or by reducing the detail.”
2. “Increase the timeout value to allow more time to complete more intensive rendering.”
Solution
By trying to change the settings in the NVIDIA control panel I was able to successfully run Rhino 7. I have recorded my search for the problem and published it on youtube, so that someone with similar problems can figure out how to fix their problem.
There is no sound in the video and my operating system has a german interface, but I hope the video helps anyway.
***Updated on 6.2.2021***: SystemInfo-Content attached (you can also see the same at the end of video)
Rhino 7 SR2 2021-1-21 (Rhino 7, 7.2.21021.07001, Git hash:master @ 96ff97351fbdf5d2acdeaf781aea1577f2ff60f7)
License type: Evaluation, Build 2021-01-21
License details: Stand-Alone
Expires on: 2021-05-02
Windows (Physical RAM: 24Gb)
VersionMajorMinorServicePack failed
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA Quadro 600 (NVidia) Memory: 1GB, Driver date: 2-6-2017 (M-D-Y). OpenGL Ver: 4.5.0 NVIDIA 376.84
> Accelerated graphics device with 2 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.50 NVIDIA
Driver Date: 2-6-2017
Driver Version: 21.21.13.7684
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.2.21021.7001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.2.21021.7001
It would be useful if you posted the results of the Rhino command _SystemInfo
Thanks for the tip, added the contents of the file “_SystemInfo” to the spoiler at the end of the text.
This GPU is already very old.
The Raytraced mode and Rhino Render in Rhino 7 does not support this GPU, because of that.
It has only 1GB of VRAM, and with Rhino 7 pushing the GPU more it is not a surprise you had to tweak settings as you did. I don’t know how future proof that tweak is going to be though.
With the GPU in its eleventh year it may be a good idea to look into upgrading where you can.
You can get out a bit of vram
And under Systemsteuerung\Darstellung und Anpassung\Anpassung
set Desktophintergrund auf einfarbig
TDR can be increased via registry, but effect questionable.
As Natan says, GPU Rendering nopes
