I found a bug in Rhino7(maybe). If I use [contour] command (in Rhino or Grasshopper). It will have broken curves in Rhino7, but no problem in Rhino6. The image describes this. And GH file is also attached here.
Thank you very much!
Have a nice day!
Thank you, Toni, for this time it works!
But I also want to know why have different results based on the same absolute tolerance, between Rhino6 and Rhino7.
Thanks a lot!
