Rhino6 crashes all the time when I use reduce meshes
hi my Mac crashes all the time when I use reduce meshes. I’ve updated macOS and reinstalled rhino 6, but still crashes.
Hi Sewon Kim,
Can you provide your SystemInfo? (type in Rhino command line)
Thanks
thanks for fast feedback!
Rhino 6 SR35 2021-8-10 (Public Build, 6.35.21222.17002, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Educational, build 2021-08-10
License details: Stand-Alone
Apple Intel 64-bit macOS Version 13.4 (Build 22F66) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro16,1
Machine name: Woni’s MacBook Pro
Language: en
AMD Radeon Pro 5500M OpenGL Engine (OpenGL ver:4.1 ATI-4.12.7)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 4 GB
Graphics: AMD Radeon Pro 5500M
Displays: Color LCD (264dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (4 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
Rhino plugins
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.35.21222.17002
Thanks. Does this happen only a on a particular model or even on a simple mesh? Can you give step by step instructions to reproduce as well as a file if need be?
Note that Rhino 6 is only supported up to macOS 11.7.6 (Big Sur)
yep it also crashes with simple mesh. my fellows rhino works totally fine with same mesh file but only mine crashes.
Do you and the other user have similar SystemInfo?
one thing you can try is resetting your Plist.
https://wiki.mcneel.com/rhino/mac/resetprefs
I tried both way using command, using Terminal, but still crashing…
is there any other option?
I’m not running an old mac with Rhino 6 to test. You can download a trial of Rhino 7 or post the file for testing there (new macOS with Rhino 7). I can test on Windows Rhino 6.
