Rhino6 crashes when i open material panel
I am running Rhino6 in my new MacBook Pro (MacOS MONTEREY).
The app crashes as soon I open the render material panel, regardless of the file. Even a new file with nothing in it would crash.
Would you please assit me with this ? Thanks a lot
Hi Julia -
Could you please run the Rhino SystemInfo command and copy-paste that information here?
attached info. Thank you!
Rhino 6 SR35 2021-8-10 (Public Build, 6.35.21222.17002, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo. In use by: Julia Rubio Benavente (Prolimit)
Apple Intel 64-bit macOS Version 10.16 (Build 21A559) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro18,1
Machine name: Julia’s MacBook Pro
Language: en-ZA (MacOS default)
Apple M1 Pro (OpenGL ver:4.1 Metal - 76.1)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: n/a
Graphics: Apple G13X
Displays: Unknown (255dpi 2x), Unknown (81dpi 1x)
Graphics processors
Apple G13X (N/A)
Color LCD (1728 x 1117 @ 120.00Hz)
DELL SE2722H (1920 x 1080 @ 75.00Hz)
USB devices
Western Digital: Elements 2621
Logitech: USB Receiver
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
Rhino plugins
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.35.21222.17002
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.35.21222.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.35.21222.17002
Good morning,
I have the same problem on my new MacBook Pro ( MacOS MONTEREY Version 12.1 (21C52). Do you have find a solution to the problem?
Hi -
Running Rhino 6 on Apple Silicon is not supported.
