Rhino WIP has no way to revert to default button image
Whilst tweaking toolbars I changed a button’s dark mode image options from ‘Use a different image’ to ‘Recolor light image for dark modes (sic)’. This changed the dark mode icon from white lines on a dark background to black lines on a dark background which is unusable.
There is no apparent way to revert to the default image. I had to find the XML file where Rhino records such customisations and delete it (thereby losing any other changes I might have made).
Please add ‘Revert to default image’ options wherever icons are edited.
TIA
Jeremy
I’ve created a ticket so that this is on my list :slight_smile:
https://mcneel.myjetbrains.com/youtrack/issue/RH-92016/Make-reverting-to-default-image-easier
