Hey Rhino guys,
I’ve been having some problems lately with rhino using blocks. Once in a while when im replacing or editing a block, my entire file turns white, including all viewports and with nothing to select.
When a show all in the file only a fragement of the original files geometry comes back.
Ive tried
_NoEcho _-Layer _On * _Enter
_Select _Pause _NoEcho _SetRedrawOff _SelNone _-SelLayer _Pick _SelPrev _Enter _SetRedrawOn
but nothing shows up except some random fragments - and the file is still as big as the “original” So the geometry is baked into the file, i just cant see/select it,.
Luckily I can go back and take an old autosave, but its getting quite frustrating.
System info:
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Commercial, build 2023-02-27
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 64Gb)
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
- Windows Main Display attached to adapter port 1
Primary OpenGL: NVIDIA Quadro RTX 3000 (NVidia) Memory: 6GB, Driver date: 6-10-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.25
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-10-2023
Driver Version: 31.0.15.3625
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.22353.1023
C:\Users\fhe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\BIM360FileLockerForRhino\1.0.0\BIM360FileLockerForRhino.rhp “BIM360FileLockerForRhino” 1.0.0.0
C:\Users\fhe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\ggRhinoIFC\2.1.28.0\ggRhinoIFC.rhp “ggRhinoIFC” 2.1.28.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Users\fhe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\SectionTools\2021.4.30.511\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Users\fhe\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\PanelingTools\2021.3.2.446\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\BlockEdit.rhp “BlockEdit” 7.28.23058.3001
