Edit Block in Detail Rhino 8
Is this purposeful behavior, and if so, is there a way to overwrite the default? I’d like to be able to edit blocks from inside details.
Thanks,
Alan
Rhino 8 SR6 2024-3-26 (Rhino 8, 8.6.24086.11001, Git hash:master @ 8e3b686f596bb6443e56e6dbecf0f54f4888713a)
License type: Commercial, build 2024-03-26
License details: Cloud Zoo
Windows 11 (10.0.22635 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.17
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3060 (NVidia) Memory: 12GB, Driver date: 3-12-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.86
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 3-12-2024 (M-D-Y).
- Secondary monitor attached to adapter port 0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-12-2024
Driver Version: 31.0.15.5186
Z-Buffer depth: 24 bits
Total Video Memory: 12 GB
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\CodeListener (8c4235b6-64bc-4508-9166-bef8aa151085)\0.1.7.0\Rhino 5.0\x64\CodeListener.rhp “CodeListener” 0.1.7.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\CLines_Pascal\CLines.rhp “CLines” 0.1.8023.28213
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\OVFP-Rhino-UE-Bridge\0.7.4\OVFP Rhino UE Bridge.rhp “OVFP Rhino UE Bridge” 0.7.8600.22536
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Cephalopod\0.0.2.0\Cephalopod.rhp “Cephalopod” 0.0.1.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\rhinopbrmaterial\1.1.4+v6.16\RhinoPbrMaterial.rhp “RhinoPbrMaterial” 1.1.2.0
C:\Users\alanf\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Rhino 8\Plug-ins\SolidTools.rhp “SolidTools”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.6.24086.11001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
Not seeing it here, is there a different workflow you are using?
Hm, ok. This could be because I use BlockEditNew plugin. May have to update it, or wait for an update. Assuming that’s the culprit. Thx so much.’
Will try this in Safe mode when I have a time later and report back.
