Rhino to Autocad export text mirroring issue
Hello all,
I know that Rhino has a setting that makes text read forward even when it’s mirrored, so when it’s exported as DWG or another format the text is upside down or mirrored. I wonder if there’s a script or a method to fix this issue. Thank you!
Renan
I have also had this problem for a long time… A solution would be great!
Hi -
If you frequently have to send files to AutoCAD, you should probably consider changing the setting in the annotation styles that you use.
orientation fixer forum.gh (16.3 KB)
Here is a quick fix
