When I export to DWG or explode my text, the text becomes mirrored. How do I prevent this?
Hi Steve, dag Hans -
Thanks for reporting this.
I see this was fixed for Rhino 6 but somehow became unfixed again and I’m not sure if that was on purpose or not.
I’ve reported this as RH-67110 for a developer to take a closer look.
When it comes to text, if you turn off the Orient text toward reader when viewed from behind setting in the annotation style, you will see that the mirror text is, in fact, mirrored in Rhino as well. As a work-around, text (as opposed to dimensions and leaders) can be fixed by rotating it 180°.
The issue is still here in Rhino 8 !
I wish that the export of text to DWG was a bit more Wysiwyg as in “don’t screw my text please”.
-Don’t move it
-Don’t flip it
Just export the darn text to DWG as it shows in Rhino 'cause that’s how I want the other folks to see it.
240522_MOD_Export to dwg and cry.3dm (1.1 MB)
Hi @wim ,
I have the same issue. As you can see below, I have mirrored group objects in Rhino. As a result of dwg export, the orientation of my texts in the group is lost.
Rhino8:
Autocad:
orientation fixer forum.gh (16.3 KB)
Here is a quick fix to this problem
