Rhino stopped opening file, black screen
file stopped opening and screen is black. thought it was the visualarq plugin and have since uninstalled it but the issue continues. seems as if the screen is frozen and can’t click on command bar or anything else.
rhino is able to open on its own but not when opening this specific file.
Rhino 7 SR28 2023-2-27 (Rhino 7, 7.28.23058.03001, Git hash:master @ 4ffc5d7156fbccf2a5d9fcc80e522b3851bc7f6c)
License type: Educational, build 2023-02-27
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 15Gb)
Computer platform: LAPTOP - Unplugged [50% battery remaining] ~40 minutes left
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 8-30-2022 (M-D-Y).
> Integrated accelerated graphics device with 5 adapter port(s)
Primary OpenGL: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 5-22-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.98
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-22-2022
Driver Version: 30.0.15.1298
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.1.1.0
C:\Users\vasqu\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Corgi\0.3.0\Corgi.rhp “Corgi” 0.2.0.1
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\LadybugTools\1.38.5\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.5.0
C:\ProgramData\McNeel\Rhinoceros\packages\7.0\Pollination\1.25.11\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.25.11.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.28.23058.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.28.23058.3001
Hello- please disable all of the plug-ins listed under ‘Rhino plugins that do not ship with Rhino’ in your system info, then close and re-open Rhino - any better? If not also disable the legacy Rhino renderer and restart Rhino. Does that change anything?
it did not >.<
Hello- can you open the file if Rhino is opened in Safe Mode?
Please ensure your power setting are set to performance, you are currently unplugged and if its using the 1 GB Radeon it 's likely the cause (you can also uncheck GPU tessellation as well, a known Radeon driver issue for primary Radeon cards)
Good evening, when I put the box in Rhino 8, I get a black screen. When I remove it by clicking the right mouse button, the gray screen with the grid is restored again. What’s the problem?
Hi Maks,
Lets start by running SystemInfo in the Rhino command line and post the results. Thanks
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Evaluation, build 2024-11-12
Expires on: 2025-02-24
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 8GB)
.NET 7.0.12
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) HD Graphics (Intel) Memory: 2GB, Driver date: 8-6-2020 (M-D-Y). OpenGL Ver: 4.0.0 - Build 10.18.10.5161
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.0 (primary GPU’s maximum)
Anti-alias mode: 4x
Vendor Name: Intel
Render version: 4.0
Shading Language: 4.00 - Build 10.18.10.5161
Driver Date: 8-6-2020
Driver Version: 10.18.10.5161
Total Video Memory: 2112 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
The very old driver is most likely the issue, on a less than recommended size video card. Rhino - System Requirements
And how can it be updated?
The latest drivers are supplied by the Video Card Manufacturer
https://www.intel.com/content/www/us/en/download-center/home.html
