Every other rhino file opens but not this particular file. I have no idea why this is happening. Can I get some help opening this rhino file?
Can you type System Info in the command line and paste the results here?
Does it come in via worksession??
In a new instance of Rhino lets try the SystemInfo, before trying to worksession or open the file again. What is the size of the file?
The file size is 120MB
Here is the systeminfo from a new rhino file.
Rhino 7 SR12 2021-11-9 (Rhino 7, 7.12.21313.06341, Git hash:master @ 5590153808223b57a9f41516a969fd949aa81bff)
License type: êµìœ¡ìš©, build 2021-11-09
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 16Gb)
Computer platform: LAPTOP - Plugged in [33% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 9-25-2019 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 2070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Users\yhd13\AppData\Local\Programs\Enscape\Bin64\Enscape.Rhino7.Plugin.dll “Enscape.Rhino7.Plugin” 0.0.21124.1031
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21313.6341
Hi @user1380,
If you disable Enscape before loading the file, do you get any further?
Tools > Options > Plug-ins
– Dale
No… it’s still not opening.
I don’t have any problems opening other files. It’s just this one that doesn’t open.
would you mind try opening the file there? If you can share a link, I will upload the rhinofile there.
Lets make sure your Hybrid Graphics is setup properly, with the low battery it may be using the Intel.
You can upload the file here Rhino - Upload to Support
Let us know the filename and send to Support@mcneel.com
I just uploaded the file and also sent an email. thanks
