hello, I’m trying to export my model for 3d printing, and when I export to stl file it becomes cracked and rebuild with boxes.. How can I fix this? I tried to change the exporting option but it doesn’t. change.
Hello- is your object very far from the World orign?
Yes I thinks so does that matter??
Hello- yes it does - meshing precision is lost at distances very far from the origin - if you move or copy your object to the origin (world, not CPlane) then generate the mesh there, it should clean up.
https://wiki.mcneel.com/rhino/farfromorigin
thank you so much I was really crying a whole day!!
thank yo so so much, I wasted like 6 hours trying to solve this problem until i saw this and solved it in 5 minutes, THANKSSSSSS
