Rhino 5.5.5 for Mac reports the attached object as a valid polysurface but when I export it as a mesh (STL) the result is incorrect. In the screen grab, pink is the 3DM, blue is the exported STL.
Then you mesh settings are incorrect for your needs.
Best practice suggests:
Use the Mesh command to create a mesh from your closed polysurface. Adjust the mesh creation settings to get the mesh density and fit that your printer requires.
Hide the polysurface
Inspect the mesh using the Check command to make sure it is a good, closed mesh. Repair as needed.
Export the mesh to STL.
For your object, these settings make a better fitting mesh:
That said, I do not like how complicated and over parameterized the wide areas are on your wheel. This excessive control is likely to cause down-process problems.
Your mesh settings indeed cure the problem but in so doing take the file size from 6 to 140 MB!
What I don’t understand is that I have exported the same design as a mesh with only a couple of structural alterations to parts not associated with those that produce the problem without issue. Normally, I don’t have to tamper with the default mesh settings at all.
How would you suggest I de-complicate the wide areas of the wheel? I assume you are referring to the 6 concave surfaces. I created these using the Network Srf command using only 4 open lines and do not see how I can make these surfaces simpler without losing the edge matching tolerance I wish for if moving to machined parts.
Hello - please try this: Start DivideAlongCreases, set SplitAtTangents = Yes, then select the object and Enter. Then mesh at your previous settings and see if that looks any better.
That makes the issue further confusing, as I obtained no change in V5 – but, perhaps I need to repeat to make sure.
I have tried something though…rather than using Network Surface to obtain the concave surface indents, I have simply swept a 0.5 mm radius arc around a single rail then capped it with a flat base. When I do this, I have no problem exporting as a mesh using the default settings (see attached). Does this provide any clues?
