Hello, Today I updated my rhino and I am facing a problem. The shaded view shows transparent walls when I go inside! Is there a way to solve this?
Hello- Backfaces of closed objects are automatically culled. If you are putting the camera inside a closed object then indeed it will not render the inside to that view. Pulling one surface out from the object will open it.
Earlier this doesn’t use to happen !
Hi -
As far as I can tell, the current behavior has always been present in Rhino.
