Hey!
I have a very strange issue… I recently needed to do some work in T-Splines, so i downloaded the demeo version of RH5 and T-Splines and worked with it. Ok, but then I uninstalled it again because I use RH6 usually, but since then I gues the message to update my plugins (one of them T-Splines) when I start up RH6. And worse when I attempt to save files or close Rhino, I very often get a bluescreen… I do not understand this behavior, especially because I already uninstalled RH5 and T-Splines…
Would be very happy if someone could help me here.
Greeting from Austria
