Rhino runs very slow!
Hi Muhammet -
Thanks again!
When I open that DWG file in Rhino and run SelDup, I get the following:
Found 768 duplicates. 1 point, 767 curves added to selection.
In that file, zooming to extents shows this:
When I open the 3dm file that you sent us, however, I get this:
Found 77810 duplicates. 623 block instances, 12 points, 75708 curves, 112 surfaces, 750 texts, 605 hatches added to selection.
And zooming to extents shows this:
Apparently, the file that you are testing in Rhino is not quite the same as what you are using in AutoCAD… Is that something that you can confirm?
It’s absolutely true, I tried the same way after you. I imported the DWG from scratch and the file became much easier. I don’t understand why the first file is copied so often. Thank you very much. For me I need to spend more time with Rhino.
Not seeing much of speed difference.
looping gif of copying in Rhino & Autocad
AutoSadCompare
I think the reason why AutoCAD feels faster is because I triggers “Adaptive Degradation” when a certain % of the objects are hidden while transforming objects. in both AutoCAD and Rhino tests, neither my GPU or CPU was fully utilized, most of the utilization came from OBS capturing the screen in the background
System Info
Rhino 8 SR3 2023-12-5 (Rhino 8, 8.3.23339.02001, Git hash:master @ 935104203bbc533bfe75e647b85776d0801560f6)
License type: Commercial, build 2023-12-05
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32Gb)
.NET 7.0.14
Computer platform: LAPTOP - Plugged in [97% battery remaining]
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 10-6-2023 (M-D-Y).
- Windows Main Display attached to adapter port #2
Primary OpenGL: NVIDIA RTX A1000 Laptop GPU (NVidia) Memory: 4GB, Driver date: 10-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.01
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 10-26-2023
Driver Version: 31.0.15.4601
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.23339.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.23339.2001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.23339.2001
C:\Program Files\Rhino 8\Plug-ins\import_ACAD.rhp “AutoCAD file import: import_ACAD”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.23339.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.23339.2001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.23339.2001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.23339.2001
I tried to find out if a certain object type could be the cause.
Apparently that’s not the case.
Make a new model and paste:
_Circle 0,0,0 1
_SelAll
_Array 320 320 1 3 3 _Enter
_Zoom _Extents
Results in ~100000 objects.
Or try a point instead of a circle.
Display speed is fine.
When it comes to _Move or _Copy I see the performance drop.
I assume it has nothing to do with the display.
right click to Rhino icon then select “Troubleshoot Compatibility”. idk why but sometimes Rhino8 may be installed with compatible to Win8. Troubleshoot will change this for your OS. i hope this will solve your issue. At least it worked for me. By the way, after this you also need to adjust the other display settings like antialiasing, OpenGL etc.
